Differential drop, not seated right?
Discussion in '1st Gen. Tacomas (1995-2004)' started by lonzorizo, May 5, 2011.
  1. May 5, 2011 at 12:05 PM
    lonzorizo
    lonzorizo [OP] Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
    Put my front diff drop in and I noticed it doesn't look right. The piece on the bottom doesn't sit flat. See pic below and you'll know what I'm talking about. Is this normal or did I do something wrong along the way?
  2. May 5, 2011 at 3:39 PM
    lonzorizo
    Lonnie
    Hoopa, Ca
    The instructions said to re-use the factory washers, but the factory washers don't come off the bolt. Is this where the problem lies?lol
  3. May 5, 2011 at 4:40 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    ya those dont look right, here some pics of what mine look like
  4. May 5, 2011 at 5:59 PM
    lonzorizo
    Lonnie
    Hoopa, Ca
    What the hell I just took the drop out, and re did it with spacers and it still looks like that. I been noticing a little clunk goin over slow bumps now too probobly related? Think ill just ditch the diff drop I didn't even notice a difference in cv angles.
    Edit: clunk noise still persistent with diff drop out. Guess I'll throw it back in tomorrow might as well use it since i bought it.
  5. May 6, 2011 at 6:20 PM
    Hoyt
    Hoyt Well-Known Member
    Green Cove Springs,FL
    03' SR5
    Fabtech Dirt Logic 6" OME 881 Springs Custom Leather Spidertrax Wheel Spacers Deaver Leaf Pack Light Racing UCA's Diff breather mod Scangauge II Doug Thorley Headers Magnaflow Exhaust TRD Supercharger AEM Intake Transmission Cooler ARE Topper Relentless Armour IPT Valve Body Smittybilt X2O 8000 w/ 12 Volt Guy incab controller URD 7th injector Kit AEM Water Methonal Injection Kit Devil Horns Smittybilt Air Compressor
    Does the diff drop adjust the suspension height? Got a 3" sus lift now and am going to add Fabtech shocks that are adjustable was told to get a diff drop to help with the angle of the cv but I don't want it to lower the front end. Be gentle...
  6. May 7, 2011 at 10:52 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    First, it is never a good idea to "stack" lifts. If you already have a spacer lift, it is not a good idea to add adjustable coilovers to increase beyond 3".
    A diff drop, as the name implies, lowers the diff just a smidge. This in turn, helps with the axle angles. If you will post a pic of your axles, it'll help to know whether or not it will help in your situation.
  7. May 8, 2011 at 12:23 AM
    Taco4Fish
    Taco4Fish Well-Known Member
    j
    I have the diff drop, read up plenty articles about it got mixed reviews, decided what the hell and bought the toytec one, just by my eyes it doesnt look like it did anything to the cv angle. Just ended up lowering my shocks to 2.25" left the diff drop in.
