differential drop
Discussion in 'Suspension' started by nurseboy, May 19, 2009.
  1. May 19, 2009 at 1:05 PM
    nurseboy
    nurseboy [OP] Well-Known Member
    Jan
    Riverside, Ca
    just to clarify before i go under the truck. Since I just lifted the front end of the truck and its already on all 4 tires, is it still necessary for me to jack up the truck a few inches, put on jack stands, then lower the front diff to put the spacers in for the differential drop (from the ultimate lift kit from toytec). Or will I be good to go to just put a floor jack under the diff, unbolt and lower it a few inches to put the spacers in? I don't want to work more then I need to. Thanks....
  2. May 19, 2009 at 1:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You dont need to lift the truck.
  3. May 19, 2009 at 1:14 PM
    nurseboy
    Jan
    Riverside, Ca
    I love this forum, especially Chris because of all the info and the fastest replies ever! Thanks man
  4. May 19, 2009 at 4:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL, Your welcome. :)
  5. May 19, 2009 at 4:02 PM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    All you have to do is brace it with a jack (just as a precaution) undo the bolts. Pry down the diff and slide in the spacers. Put your new bolts in. Easy as pie. Takes about 15-20 minutes.:D
  6. May 19, 2009 at 8:01 PM
    nurseboy
    Jan
    Riverside, Ca
    I'm a failure with working on this truck....
    So I just attempted to do this and failed. I was unable to take of the nut on top because of its hard location + that shit is just really on tight (going at it tired and hungry). I am at a time constraint and needed to stop because I have work tonight. Any suggestions next time I try? And I know relentlesstaco said I DO need to put them on because im 4x4, but will I F**k something up that bad that I absolutely can't drive? Please say no because its my only transportation to work. work is about 15 miles. I can work on it again thursday afternoon...
  7. May 19, 2009 at 8:26 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Unless it's something you have done a number of times, like an oil change, it's never good to start a project when there is a chance you may not finish it. My suggestion will be wait till you have all day to work on it so there will be no rushing, don't want to forget to tighten something.
    Good luck.
  8. May 19, 2009 at 10:49 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    you'll be fine driving w/o it. i've been driving w/o the dif drop since october. I just ordered it last week. it wont hurt to wait a few days
  9. May 19, 2009 at 11:52 PM
    nurseboy
    Jan
    Riverside, Ca
    i hope so. this is going to make me feel more re-assured and not worry rest of my night shift here at work
  10. May 20, 2009 at 4:44 AM
    badguybuster
    Michael
    You are right, it can be tough to get the top nut off. Spray it down with some WD 40 and let it set for a few minutes. I was able to wiggle in a longer socket wrench which gave me some more leverage.
  11. May 21, 2009 at 5:13 PM
    nurseboy
    Jan
    Riverside, Ca
    just got back from trying to do the diff drop again and my dad tried to loosen the bolt for me and asked to see it. when he compared it, he pointed out that the bolt is going to be way to long, about 1/2-1inch to long...do you guys think they supplied me with the wrong bolt, the lenght is 8 1/4 inches long...here are pics to show what i mean.
    you can see where the bottom of the threads are way above to where i can bolt down to the frame. Am I just eyeing it wrong?
  12. May 21, 2009 at 5:58 PM
    badguybuster
    Michael
    Nope. That looks right. Once you get into place you'll see it is right.
  13. May 21, 2009 at 11:03 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    I think the bolt is only supposed to be about 6 inches long..
  14. May 22, 2009 at 12:23 AM
    nurseboy
    Jan
    Riverside, Ca
    if it is, then i got screwed. Ill be calling toytec tomorrow. Hopefully they fix it even though I ordered this from them back in April 1. I just never had the chance to put it on.
  15. May 22, 2009 at 1:41 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    check the instruction piece of paper that came with it, i know it says how long the bolt is. I just read it yesterday morning and im pretty sure it said about 6", but i could be wrong, and i threw the paper away
  16. May 22, 2009 at 2:21 PM
    nurseboy
    Jan
    Riverside, Ca
    I already contacted toytec and they said they sent me the diff drop kit for the older tacoma. They shipped me new bolts today.
  17. May 22, 2009 at 2:26 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    sweet. a trick to un-bolting the OEM crap (if you dont have an impact), stick a wrench on top, have a buddy hold it, put a socket on the bottom and stick a pipe on it. this will make it a lot easier
