Differential fill plug leaking??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chapman1991, Apr 9, 2025.
  1. Apr 11, 2025 at 7:13 PM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    I agree, replace, even though you axle seal leaking may have nothing to do with the vent, sometimes they just leak...
    I have no idea what the toyota diff vent looks like, just generally speaking...
    Some vents have a top cap...
    The cap is suppose to be floating say in the middle position,
    sometimes the top cap gets shoved / pushed all the way down, bottomed-out, that will restrict venting.....
    Just bit of education is all, if it has a top cap & its moves, dont install it by shoving down on that....
  2. Apr 11, 2025 at 9:05 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Agreed.
  3. Apr 11, 2025 at 9:05 PM
    Waasheem
    Waasheem
    2007 xrunner
    The stock plug kinda sucks because it’s so short. Even if you have snapon tools, getting it to not slip n strip is tricky. The Lexus plug is more robust and less likely to strip.
    If you let quickie oil change places touch your car, some goof ball can open up your differential without your consent just to show you the color of the gear oil. Then slam it back on with an impact driver and cross thread strip and chew it up. Happened to me the last and final time I used one of those places.
    https://www.tacomaworld.com/threads/front-diff-drain-plug-alternate-oem-part.604989/
