Differential Fluid Adventures
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SeniorSpan, Apr 25, 2017.
  1. Apr 25, 2017 at 9:11 AM
    SeniorSpan
    SeniorSpan [OP] Well-Known Member
    Bob
    Colorado Springs
    23 TRD DCSB OR
    Tacoma Drivers
    2011 DC TRD OR
    20-30% off roading
    Spent several days reading through the TW threads concerning the "How To" procedures for selecting the correct differential fluid and changing the fluid. Got the correct gear oil, now to the change process.
    Realizing I was behind the power curve for changing the fluid (79,000) I was really concerned what was gonna drain out. Following the suggestions in the TW threads, I remover the spare tire and loosened and removed the differential fill bolt. Inspected the existing fluid and was very surprised to find the existing fluid was very light amber in color, just about identical to what I had to replace it. I realized fluids break down with time and I should continue with the change, but was wondering if this is an abnormal/unusual situation?
    Thanks
    Bob
  2. Apr 25, 2017 at 9:43 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I'm wondering if your truck was filled at the factory with that mega-bucks Toyota-branded differential gear oil. Some of that stuff is something like $35-$?? a qt. I do not recall the part number(s) off hand. I believe one is for limited-slip diffs and otherwise.
  3. Apr 25, 2017 at 9:44 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Yes still change the oil. You're already that far in.
  4. Apr 25, 2017 at 9:46 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    No reason to change this every 30k miles unless you just got new gears or drive through deep water a lot. My dad went over 300k miles without changing the gear oil in his diffs
  5. Apr 25, 2017 at 6:26 PM
    SeniorSpan
    Bob
    Colorado Springs
    23 TRD DCSB OR
    Thanks for the replies.
  6. Apr 25, 2017 at 6:47 PM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I changed the front on mine at 50k and it was pretty nasty. Also changed transfer case which I will never do again. No sense for how much I use 4wd compared to 2wd.
