Differential Fluid Change 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoForMe73, Feb 4, 2022.
  1. Feb 4, 2022 at 11:14 AM
    TacoForMe73
    TacoForMe73 [OP] New Member
    Hi Everyone, Looking to change my differential fluids in my 2014 2nd Gen Tacoma 4wd. I was thinking of using the Valvoline Synthetic SynPower SAE 75W-90. It says it has the additives for the limited slip differential. Anyone use this before? I know the manual states to use SAE 75W-85. Only brand I found online for this is through Redline. Thxs in advance for info!
    Made a mistake with my first post. My Tacoma is a 2014. Keep getting confused with the wife's Sequoia. Sorry about that. From what I just read that is considered 2nd Gen. 3rd Gen, 2016 - up. All screwed up today!!!
    Ponine31 and boston23 like this.
  2. Feb 4, 2022 at 11:16 AM
    Tacospike
    Two Trucks
    I used redline
    trabo and TacoForMe73[OP] like this.
  3. Feb 4, 2022 at 11:19 AM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    Do you have a mechanical LSD?
    also I used the Toyota 75w-85.
  4. Feb 4, 2022 at 11:20 AM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    I don't think any 3rd gens have a mechanical limited slip, it's just brake actuated, so you don't need the additive. The manual should tell you if you need it.
  5. Feb 4, 2022 at 11:27 AM
    dfanonymous
    It doesn’t.
  6. Feb 4, 2022 at 11:30 AM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    As long as it meets toyota design standard (GL5 iirc), it will be fine. There’s zero functional difference between 75w90 and 75w85
    TacoForMe73[OP] likes this.
  7. Feb 4, 2022 at 11:31 AM
    TacoForMe73
    Thanks everyone...The manual doesn't say I need an additive. It says Toyota Genuine Differential Gear Oil LT 75W-85 GL-5 or equivalent. From what I read online LT stands for Non-Limited Slip Differential. It sounds right. Not sure. I just checked out the Valvoline website and it recommended the exact Valvoline product that I am looking to use, Valvoline SAE 75W-90 Full Synthetic Gear Oil
    roboturner likes this.
  8. Feb 4, 2022 at 11:31 AM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    I think I remember seeing somewhere that the proper weight of the 3rd gen rear diff fluid is like 130 or so if you want max protection 0 regard to mpg
    anyone knows what I'm referring to? I can't seem to find that
  9. Feb 4, 2022 at 11:35 AM
    C4vettrn
    C4vettrn Well-Known Member
    Randy
    Ft. Wayne IN.
    2015 trd 4x4
    17" SR8's
    I use the Valvoline. It is one of the best and the additive won't hurt anything. My local Napa stocks it. There is a lot of info on oils if you do a search. Go to sites like Bobthe oilguy or people that deal with differentials etc. Forums will have people giving all sorts of info and just you scratching your head.
    TacoForMe73[OP] and NAAC3TACO like this.
  10. Feb 4, 2022 at 11:37 AM
    OpeCity
    Long Beach, CA
    LS = for limited slip
    LT = non-limited slip
    either will be fine in a non-limited-slip diff
  11. Feb 4, 2022 at 11:47 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You have 2 options
    Pay a premium for 75w-85 and not worry about it.
    Or use widely available and cheaper 75w-90 synthetic. And I still wouldn’t worry about it.
    While I’m not a 3rd Gen, I’m running 85w-140 front, and 80w-90 rear.
    Neither of which is the actual viscosity stated in the manual. I haven’t worried about it any of it. :confused:
    OpeCity and TacoForMe73[OP] like this.
  12. Feb 4, 2022 at 11:52 AM
    TacoForMe73
    Thanks for reply TNShooter...You had me laughing....I am choosing option 2...And "not going to worry about it"... :) LOL
    NAAC3TACO and TnShooter like this.
  13. Feb 4, 2022 at 11:53 AM
    saint277
    saint277 Vigilo Confido
    The "lsd" in these trucks is just the brake system applying the wheel brake to the the side that has a spinning wheel, the differential is a standard open diff. I like the redline 75/85, unless your towing near the max capacity of the vehicle or have big tires there is no reason to use a higher weight and I like using the recommended fluid. Increasing the fluid viscosity will increase the resistance to flow, that in turn will generate more heat in the fluid and less heat is almost always better in the long term. 75/85 has enough film strength on a stock or lightly loaded truck to not wear the gears and going higher wont give you less wear unless your truck is moded or towing heavy wieghts.
    RustyGreen and TacoForMe73[OP] like this.
  14. Feb 4, 2022 at 11:55 AM
    OpeCity
    Long Beach, CA
    Someone at bobistheoulguy just penned a seven page rant about this post and then dropped dead of an aneurysm
    PlymouthJLA, Bronxguy and ds8466 like this.
  15. Feb 4, 2022 at 12:04 PM
    saint277
    I like the redline, its very good oil and they have it in the right weight so my ocd like its it, I also use there transfer case fluid in my truck. That sae 75 stuff(mt-lv).
    trabo likes this.
  16. Feb 4, 2022 at 12:12 PM
    tonykarter
    tonykarter Crappie Savant
    Snuff Gully, Texas
    2018 DCSB 4x4 Sport 1993 4Runner SR5 4x4, 411,000 miles
    Pine tree air freshener
    Same 75-90W GL5 in the transfer case? Nathan, you have those magnetic drain plugs back in stock yet? That's what I'm waiting on to do mine.
  17. Feb 4, 2022 at 12:16 PM
    saint277
    Transfer case takes a sae 75 gl-4, using A GL5 instead of a gl4 is not a good idea, they are not interchangeable. Only non toyota fluid is made by redline, there mt-lv fluid. the toyota brand fluid is 50 bucks a quart.
    trabo and RustyGreen like this.
  18. Feb 4, 2022 at 12:23 PM
    OpeCity
    Long Beach, CA
    There are lots of non-toyota GL4 oils besides redline
  19. Feb 4, 2022 at 12:32 PM
    TnShooter
    Deogee
    STOCK
    What?
    You have a link?
    I mean, I’m just not all that worried about a few viscosity points. I have much bigger problems to worry about. :thumbsup:
  20. Feb 4, 2022 at 12:45 PM
    saint277
    A 75 strait weight? No there isn't, and red line actually has the Toyota fluid (Genuine Transfer Case Gear Oil LF 75W 08885-810800) listed in there product data sheet. I believe that the are 2 more, but they don't list the Toyota oil in there data sheets.
    link to the red line data sheet
    https://www.redlineoil.com/Content/files/tech/MT-LV_GO_PROD_INFO_2021.pdf
    Tacofanatic82, trabo and RustyGreen like this.
