Differential fluid change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chicken_Taco, Mar 23, 2022.
  1. May 28, 2024 at 2:38 AM
    #121
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    A slightly modified one gallon weed sprayer works well for pumping the fluid.
    mquibble likes this.
  2. May 28, 2024 at 7:44 AM
    #122
    2013logan
    2013logan Active Member
    New Mexico
    2019 Tacoma TRD pro
    icon add a leaf, KD max tune,RSG sliders, Falken 33inch MT, eibach spring, arb front locking diff,ARB air compressor.baja designs squadron fog lights non dot comliiant.
    I would wait till 60k for the front and i would do the rear diff before that my reasoning is the rear is used all the time and when your truck is new the gears still have to mesh and there will be metal in the diff its normal. I would like to have new fluid in the rear to get rid of the break in period contaminates go with ams oil and then do it every 60 k after luca oil is also very good east coat gear supply wrote a very informative article on diff oils explaining the best ones and why check it out. Also do this work yourself there are a million videos made by people that want to save you money.
  3. Sep 10, 2024 at 7:47 AM
    #123
    Tacodrew22
    Tacodrew22 Well-Known Member
    Andrew
    Michigan
    2022 Tacoma TRD Off-Road
    OnX Off-Road Trail Guide. I help OnX map and document routes. I get out all across the United States but based in Michigan
    I would classify myself in the server category for the diff changes. Did all diff, Tcase, and trans drain and fill at 30k. Decided then that I want to do diffs at 15k which I am coming up on. When I last did the change I used 75w-90 Amsoil severe. Would I be getting much benefit with that over say Valvoline with a 15k interval?
  4. Sep 10, 2024 at 8:09 AM
    #124
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    My thought would be the 15k intervals, which I am also doing, would keep wear down to a minimum. I also suspect most wear likely occurs during the first 10,000 miles. I also don’t recall any posts indicating diff problems, especially for those who change their oil frequently.
    I hesitate to admit that I also use Amsoil and don’t mind the slight upcharge to do this service. Here we go, they are going to come chastise me for ridiculously wasting money while they get new tires, wheels, suspension, etc. lol.
    Inyo_man likes this.
  5. Sep 10, 2024 at 8:12 AM
    #125
    Tacodrew22
    Andrew
    Michigan
    Hahaha. I definitely feel like you get what you pay for and I believe Amsoil is a quality product but for $100 more even with the member discount every 15k miles feels like a lot in the short term. Although my gut tells me I’d be happier with it and won’t overthink it. Exactly why I used it last time.
  6. Sep 10, 2024 at 3:05 PM
    #126
    Tacodrew22
    Andrew
    Michigan
    Update if anyone even cares…
    A dealer for Amsoil lives 5 mins down the road picked up 7qts from him at cost so I’m happy. Now just waiting for all the gaskets. I ordered extra of each should be good for 6 or so changes on all drive line items!
    ERod27 and mquibble like this.
  7. Sep 17, 2024 at 12:24 PM
    #127
    JMotto
    JMotto Member
    2019 TRD OR DCLB Cement
    TRD Beadlock Wheels, Nitro 4.88's, 265/75-16 toyo open country AT III's, leitner designs ACS, meso total tail lights stage 1, clazzio covers
    GBR likes this.
  8. Apr 9, 2025 at 8:08 AM
    #128
    YE2KA
    YE2KA Well-Known Member
    JB
    19 Cement Grey Tacoma Offroad
    Is 35k a premature interval to replace all the diff and transfer case fluids?
  9. Apr 9, 2025 at 8:10 AM
    #129
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Certainly not if you're the one selling the fluids or service..
    mt50u1 and ricco333 like this.
  10. Apr 9, 2025 at 8:45 AM
    #130
    YE2KA
    JB
    Very valid point...especially my truck that has never towed not even a jetski
    jmneill[QUOTED] likes this.
  11. Apr 9, 2025 at 9:53 AM
    #131
    Mac62989
    Mac62989 Well-Known Member
    2020 Quicksand Sport AC MT
    Just changed the front and rear diff yesterday at like 35,775. I am glad I did, front diff fluid looked really similar to the rear when I don't use 4WD all that much. Plan on tackling the transfer case around 60k when I get there in a few years. Ironically you read a lot on here about the front diff 10mm hex bolts being a pain, I had no trouble with those. The biggest pain in the ass was the rear diff fill plug..
    YE2KA[QUOTED] and Smacky2020 like this.
  12. Apr 9, 2025 at 12:40 PM
    #132
    YE2KA
    JB
    How much you spent on the fluids? You went OEM?
  13. Apr 10, 2025 at 2:35 PM
    #133
    Mac62989
    Bought Valvoline 75W-90 gear oil in the squeeze pouches from Amazon, think it was like $70 for 6 quarts. Spent another $10 or so on gaskets, another $8 for a 10mm hex bit, and ended up upgrading to Lexus front diff plugs. Probably right around $100 total for everything needed.
    YE2KA[QUOTED] likes this.
  14. Apr 10, 2025 at 4:42 PM
    #134
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    I know this OP is old as moses, but a little tip for anyone DIYing this. The Rear diff & Transfer case plugs call for 24mm, but it fits a tad loose, and easier to bugger them up. 15/16 is slightly smaller and fits better
    Also you can replace the 10mm hex head front diff drain plug with Lexus part # 90341-34016. Has a standard socket head and easier to work with.
    usmc2msu, nikonNUT and Mac62989 like this.
  15. Apr 10, 2025 at 5:32 PM
    #135
    jss1975snow
    jss1975snow Well-Known Member
    Jamey
    Delaware
    2018 Tacoma TRD OFFROAD
    I replaced front and rear diffs at around 60k, existing oil both looked pretty clean, then transfer case at 100k, looked very clean since I only use 4wd seldom.
    YE2KA likes this.
  16. Jul 30, 2025 at 4:11 PM
    #136
    mikelcurtis
    mikelcurtis Member
    Taco
    It's a good idea to change your diff and transfer case fluids. Opinions vary, but I use my truck a lot, it's a daily and we go on off-roading trips frequently. I change mine at 50,000 mile intervals, I just finished a change actually. And opinions will vary about fluid types, I've always used Valvoline Synpower 75-90. I know there's a couple better (more expensive) brands, but I've had great results for a long time with the Valvoline. It's easy to do yourself, can be a little messy especially with the front, but nothing too bad. Saves a lot of money though.
