Differential fluid changes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jardoo, Feb 13, 2019.
  1. Feb 13, 2019 at 4:46 PM
    jardoo
    jardoo [OP] Well-Known Member
    Beirut, Lebanon
    2016 DOUBLE CAB MGM 4X4 TRD OFF ROAD SHORT BED
    Ok, this is a really stupid question but I have to ask it because I don't know dick.
    I'm trying to change my front and rear differential fluids. Do I change the front, rear, and t case fluids? Or do I change the front and rear differential fluids?
    Basically, is the front differential the same as the transfer case? I change 2 or 3 things?
    Thank you
    4x4spiegel likes this.
  2. Feb 13, 2019 at 4:55 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I think the manual says to do all at 30k miles. No they are not the same thing.
    Front and rear diff use same fluid. Transfer case is different.
    shakerhood and Vbpiper like this.
  3. Feb 13, 2019 at 5:30 PM
    jardoo
    Beirut, Lebanon
    Can I use valvoline 80-90 in all 3 and be done?
    Thanks.
  4. Feb 13, 2019 at 5:38 PM
    Clearwater Bill
    Billy
    Largo Florida
    Its a good plan to use the viscosity and GL rating for each of the 3 units that the manual calls for.
  5. Feb 13, 2019 at 5:40 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
  6. Feb 13, 2019 at 6:41 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    If, you "don't know Dick", why are you fucking with it??
    G.
    na8rboy and cwdog like this.
  7. Feb 13, 2019 at 6:44 PM
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    It kind of depends on your usage. I swap out the rear axle gear oil more often and usually use 85W-140 unless I'm going somewhere cold. I use a lighter oil in the front and transfer case.
  8. Feb 13, 2019 at 6:50 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I wouldn’t bother with it. Especially if you don’t know any better.
    Toyota doesn’t even have a basic recommendation for changing it. The manual says every 30k under special operating conditions. Most traditional diff oils were changed every 100k or so.
    Maybe leave it and do it at 30k or 60k
    Tacoshredder and Pot_Lickr like this.
  9. Feb 13, 2019 at 7:11 PM
    max_o
    max_o Well-Known Member
    Colorado
    2018 Silver Sky DCSB OR
    Def take a looksie at the DIY, it explains everything quite well, including what fluids to use, torque specs, etc.
    Vbpiper likes this.
  10. Feb 13, 2019 at 7:42 PM
    Lt. Dangle
    Ohio
    Gotta learn somehow. I actually enjoy doing it, maybe OP will discover a new hobby.
  11. Feb 13, 2019 at 7:59 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    75w85 as per Toyota Owners Manual.
    shakerhood likes this.
  12. Feb 13, 2019 at 8:01 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Couldn’t agree more. The world needs more wrenchin’ and less whinin’
  13. Feb 13, 2019 at 8:10 PM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    If you never done it, STOP and ask for "hands on" help. See if you find another tacoMANIAC in your area to show you how and learn by seeing and doing.
    Anyhow, if you decide to venture in this action, have the right tools and sockets (since the fill and drain plugs are thin, I made a socket for this purpose) and FIRST open the FILL plug. Have seen situations where the drain plug was opened, fluid drained but the fill plug was stuck...now you are SOL without a differential.
    rubiconjp, Garyji and michael roberts like this.
  14. Feb 13, 2019 at 8:19 PM
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    Learn a new hobby on a old beater, not a newer ish truck.
    Remember the dude that wanted to check his rear brakes, and decided to press the brake peddle to see if his emergency brake was working...with the brake drum off?
  15. Feb 13, 2019 at 8:19 PM
    dweg77
    dweg77 Active Member
    2016 MGM Tacoma SR5
    OP, you can easily do this yourself... it’s very basic. Just get the tools, the gaskets, and I recommend the OEM oil for the diffs... it’s on Amazon.
  16. Feb 13, 2019 at 8:22 PM
    Lt. Dangle
    Ohio
    Maybe the Taco is his beater truck... And no offense, but in my neck of the woods working on an old beater means working on rust and F that.
    You are right though, shit can go really wrong, but this isn't hard to figure out. If he found TW, he can find youtube and helpful links.
    stun gun and shakerhood like this.
  17. Feb 13, 2019 at 8:22 PM
    Stocklocker
    17TRDORDCSBAT
    FFS......it’s like changing diff oil is akin to effin brain surgery.......all hope is lost.....time for that asteroid.
    OP.....even as a total newb, you will be more careful and do a better job of changing your own diff and transfer case oil than the dude down at the dealer who’s just thinking about his lunch, or that spliff he’s got for the end of shift.
    seadog99, boynoyce and Lt. Dangle like this.
  18. Feb 13, 2019 at 8:25 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Who waits until the end of the shift? :notsure:
    Stocklocker[QUOTED] and Paul631 like this.
  19. Feb 13, 2019 at 8:25 PM
    Lt. Dangle
    Ohio
    There is 0 guarantee the guy at the dealer doing lube changes isn't doing it for the first time either.
  20. Feb 13, 2019 at 8:25 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Should you not change the engine oil unless it’s a beater? Differential and transfer case fluid changes are pretty idiot proof.
    Stocklocker likes this.
