Differential fluid exchange at 30k?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Curtis Rasmussen, Dec 30, 2021.
  1. Dec 30, 2021 at 11:29 AM
    Curtis Rasmussen
    Curtis Rasmussen [OP] Well-Known Member
    Curtis
    2018 TRD Offroad - White Crew cab long bed
    tonneau cover cell phone holder
    I am coming up on my 35,000 mile maintenance. Service writer told me at 30,000 I need to do a front and rear differential fluid exchange. Agree??
  2. Dec 30, 2021 at 11:32 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Agreed.
  3. Dec 30, 2021 at 11:36 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Heck yeah, but be prepared for a very unfriendly estimate. I would leave the T case fluid alone until at least 60k.
    Super easy DIY.
    Kev250R, tacotoe, shakerhood and 6 others like this.
  4. Dec 30, 2021 at 11:36 AM
    Tacospike
    Two Trucks
    Couldn’t hurt. I did mine at 48k and still had a good color and minimal magnet build up
    Curtis Rasmussen[OP] likes this.
  5. Dec 30, 2021 at 12:19 PM
    CurtisF
    CurtisF Well-Known Member
    Curtis
    2019 Tacoma Off-Road
    None
    I did mine at 20,000KM and it had quite a bit of gunk on the magnet.
  6. Dec 30, 2021 at 12:20 PM
    Curtis Rasmussen
    Curtis
    Not a talented DIY person here...I will have it done. Thanks.
  7. Dec 30, 2021 at 12:48 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    If you have an oil pan and I believe a 24mm socket it takes a total of 13 minutes.
    I timed it based off of dinner.
  8. Dec 30, 2021 at 3:10 PM
    MGRS
    MGRS Well-Known Member
    '20 Tundra OR
    Absolutely do it.
    It’s also even easier than an engine oil change. DIY range for pretty much anyone with tools.
    Dealers charges for this service are hard to understand as it is less involved than engine oil. Assumption is they charge more for it because they can get away with it on an infrequent service.
  9. Dec 30, 2021 at 3:15 PM
    Vegasstunts
    Vegasstunts Well-Known Member
    16 TRD sport
    All of them.
    Diff fluid change is a perfect place for the non dyi guy to get their hands dirty and start learning the truck. Super simple and incredibly hard to mess up.
  10. Dec 30, 2021 at 3:19 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I've heard some dealers quote $700 for diffs and T case fluid change. I charge $130 ish.
  11. Dec 30, 2021 at 4:33 PM
    gForceDude
    gForceDude Well-Known Member
    A word of advice:
    Make sure that you can get the FILL plug loose & removed, before you remove the DRAIN plug.
  12. Dec 30, 2021 at 4:34 PM
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
  13. Jan 6, 2022 at 6:09 PM
    Halibut
    Halibut Well-Known Member
    Alaska
    18 OR SB MT
    I did mine at 15k, transfer case and diffs again at 30... Front and read diffs both had pretty gross fluid and alot of metal. So it depends on the use, I guess.
    I would say the service can be done really easily diy but not in 13 minutes, especially by a novice. There are many reasons this could seem daunting to a real beginner but it really is simple if you want to save the money. Although then you'd want to change the oil too, again not difficult but another thing to learn.
    However maybe it's cause I buy quarts I have to pump in, but it's never been that quick for me... Not to mention I poke around at everything else while I'm down there.
    I think if you can save over 400 after getting the tools and taking the possible 3 hours figuring out how to do it all, take the oil back to an auto parts store, etc, you should absolutely do it.
    airmax233, Barsoom and gsubioguy like this.
  14. Jan 6, 2022 at 6:16 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Squeeze Bag Gear Oil is easier than messing with the pump if you can find them.
  15. Jan 6, 2022 at 6:54 PM
    Newlyofftheground
    Newlyofftheground Active Member
    Jeffrey
    2020 Taco Off Road
    Just got it yesterday lol
    Truth!!
    I am not the most tech savvy but I did the front/rear and the TC. I found a local hoist that I was able to use for a small fee and having the truck in the air made it super easy
  16. Jan 6, 2022 at 6:58 PM
    Tacowin1013
    I drove mine up on ramps to loosen the plugs with a breaker, and then drove it off and drained/refilled. It's just too hard to get a breaker under there without lifting the truck a bit
    shakerhood likes this.
  17. Jan 7, 2022 at 4:15 AM
    Tac2021
    Tac2021 Well-Known Member
    Phil
    2021 SR5 Drk Grey Met Dbl cab 4 x 4
    none yet
    Fluid change on a Tacoma is so much easier than a GM product. No drain plugs on some of the diffs. You need to pull the covers for a drain. I haven’t done it yet, only 11k on the toy but I plan to do all three at 25k then every 35k after. The first change you get the initial break in metal, then normal wear after unless you play submarine commander. Then change it sooner.
    zoo truck likes this.
  18. Jan 7, 2022 at 4:25 AM
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    OP you got this! Oil pan, pump, correct socket & driver size. Here & youtube are great resources. Like others said, make sure you can loosen the fill before trying the drain plugs.
    I had never done any fluid other than oil and coolant but the diffs/transfer case really are straight forward and great confidence builders for routine servicing your truck. Take a few minutes, look around the belly of the truck and familiarize yourself with parts, reference youtube/online pictures for your generation truck and you should be A-ok!
    -Rorschach- and mquibble like this.
  19. Jan 7, 2022 at 5:47 AM
    pltommyo
    pltommyo Well-Known Member
    Tom
    2016 Gray Tacoma TRD Offroad
    SSO hybrid bumper, Warn winch, RCI skid trilogy, RRW sliders, everything in the cheap/free mods thread, and of course the frame recall work.
    If you are asking if we agree to do the service ... what does it say in the manual that came with your Truck? The Toyota engineers are pretty good at indicating service intervals for all components.
    If you are asking if we agree that the service writer advised you to do that .... how would we know unless we were there?
    So for me, I would say that if it is the first ... grab a wrench, get ready to smell some very pleasant fluids, and change the diffs and transfer case fluids. If it is the second ... I will abstain as I was not there and can neither confirm nor deny their statement was made.
  20. Jan 7, 2022 at 5:53 AM
    atiracer
    atiracer Active Member
    Fords too! It's that way on my 2006 Mustang. I try to do to DYI as much as I can and looking forward to some of the maintenance on my Taco. Mine is 2WD and changing the rear diff fluid looks easier then a oil change.
    gsubioguy likes this.
