Differential fluid exchange at 30k?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Curtis Rasmussen, Dec 30, 2021.
  1. Jan 7, 2022 at 3:23 PM
    #41
    Brianz1001
    Brianz1001 Well-Known Member
    Brian
    Retired on my couch with a cold beer in my hand
    too much to type
    Yes sir, it's time.
  2. Jan 7, 2022 at 4:53 PM
    #42
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Yes, let the owner get their own gear oil. I carry the front diff crush washers as well, leave it up to them if they want to change the other crush washers.
  3. Jan 7, 2022 at 5:15 PM
    #43
    Squirt
    Squirt Certified in forklifts and meme stealing =)
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can. AMP Powersteps
    It's really easy. Just did mine a few weeks ago and impressed at the savings. Though it is simple DO NOT over torque any of the plugs especially on the soft aluminum transfer case. In some cases it can end up being an expensive PITA.
    gsubioguy and Mark77 like this.
  4. Jan 7, 2022 at 5:26 PM
    #44
    trdgts
    trdgts Member
    Aaron
    16 QS Sport DCSB 6MT
  5. Jan 7, 2022 at 6:27 PM
    #45
    ds8466
    ds8466 Well-Known Member
    If they used the correct Toyota fluid that's not tooooooo bad lol. When I did the wife's 4runner I think I had about $220 in fluid.
  6. Jan 7, 2022 at 6:32 PM
    #46
    Sxottie
    Sxottie Wrenching is therapy, right??
    Scott
    Mystic, CT
    2021 TRD Sport Double Cab
    Tonneau hard cover, mud guards, yellow fog light tint, redline hood lift kit, remote tailgate lock, bed lights, window tint, invisible bra, TRD wheel cap decals, tailgate letters, blackout badge kit, LED cab lighting kit, bed hooks, red caliper paint.
    I did the front, rear and transfer case without even raising the Taco. There's plenty of clearance.
    818_Taco_4x4 and Superdave1.0 like this.
  7. Jan 7, 2022 at 6:42 PM
    #47
    Montana_Actual
    Montana_Actual ;)
    What the hell is a crush washer?
    Just put it back up there and use flex seal like a normal human. ;)
    Since we are on the subject, anyone care to give the amount of fluid these difs need? Gonna get stocked up for my gear change.
  8. Jan 7, 2022 at 6:55 PM
    #48
    Superdave1.0
    SoCal
    At minimum change the front diff fill plug crush washer. The rest are optional.
    Front diff 1.6
    Transfer case 1.1
    Rear diff 3.5-3.8
    Buy 7 quarts, should be just enough.
  9. Jan 7, 2022 at 7:36 PM
    #49
    Montana_Actual
    Montana_Actual ;)
    Thanks. Was jk btw, I always change the crush washers.
  10. Jan 7, 2022 at 7:45 PM
    #50
    Superdave1.0
    SoCal
  11. Jan 8, 2022 at 5:31 AM
    #51
    Curtis Rasmussen
    Curtis Rasmussen [OP] Well-Known Member
    Curtis
    2018 TRD Offroad - White Crew cab long bed
    tonneau cover cell phone holder
    curious what did the parts cost u? how much time did it take u to finish?
  12. Jan 8, 2022 at 5:42 AM
    #52
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    OP, if nothing else try doing just the rear diff yourself next time. It is by far the easiest to access in general, and the easiest plugs to access as far as the likelihood of smashing your knuckles on anything.
    I remember doing engine oil, tranny drain and fill, both diffs and transfer case one weekend for 60K maintenance (2nd gen keep in mind) and doing the rear diff was almost a break from the rest.
  13. Jan 8, 2022 at 5:50 AM
    #53
    tonykarter
    tonykarter Crappie Savant
    Snuff Gully, Texas
    2018 DCSB 4x4 Sport 1993 4Runner SR5 4x4, 411,000 miles
    Pine tree air freshener
    Anyone have the part numbers and/or links for all the crush washers?
  14. Jan 8, 2022 at 6:07 AM
    #54
    chstaco
    chstaco Well-Known Member
    SC
    2020 Tacoma
    gsubioguy and tonykarter[QUOTED] like this.
  15. Jan 8, 2022 at 6:16 AM
    #55
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    I did mine at 30k, then re did the rear diff 10k later cause I was having some vibrations. It was crazy dirty after 10k miles, but……I did do a couple water crossings so water might of got in.
    I do have a diff breather extension.
    so if you do water crossings, yes you need to do it more often.
  16. Jan 8, 2022 at 10:14 AM
    #56
    trdgts
    trdgts Member
    Aaron
    Its about a hour and a half job, including getting out and putting up tools. Best thing is to have a helper pump the fluid while you hold the hose in the fill hole. I paid around $300 for Redline fluids, but that also included the MT.
  17. Jan 8, 2022 at 4:55 PM
    #57
    Sxottie
    Scott
    Mystic, CT
    It was about $110.00 for the fluid and crush washers. Takes about 2 hours. Super easy DIY job. As a side note, differential fluid smells horrible!!
  18. Jan 8, 2022 at 5:24 PM
    #58
    Curtis Rasmussen
    Curtis
    Good to know!! Will let Toyota do mine.
  19. Jan 8, 2022 at 6:05 PM
    #59
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Great info from this community!
  20. Jan 14, 2022 at 3:49 AM
    #60
    Halibut
    Halibut Well-Known Member
    Alaska
    18 OR SB MT
    I would be really surprised if they used the Toyota fluid for your t case at that price, not that it matters. It's like $60/quart and you need a little more than 1
