Differential fluid exchange at 30k?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Curtis Rasmussen, Dec 30, 2021.
  1. Jun 9, 2025 at 6:16 PM
    #121
    mississippicelery
    mississippicelery Active Member
    As encouragement for anyone who thinks they can’t do this, I just did it this weekend. Take your time, follow a really good YouTube video, watch it ahead of time and make sure you have everything you need before you get started, and it’s really just not difficult.
    I do have a question though. I bought my 2022 @ 50k miles. I didn’t get around to the differential fluid until about 70k miles (transfer case and transmission are next weekend’s task.) I don’t know if any of the maintenance (other than oil I hope was changed somewhat regularly) was done by prior owner. The rear differential definitely had metal shavings in it. There was even a somewhat chunky piece stuck to the magnetic plug.​
    is this a sign of something really bad? Or since this was probably the first time it was changed, just something to look for next time? I’m not opposed to swapping out of it to get another one if that’s an indication I’m in for trouble.
    Appreciate any feedback. This forum is awesome. And it’s always fun searching and digging up old related threads.
  2. Jun 10, 2025 at 4:00 AM
    #122
    HelloFelix
    HelloFelix Well-Known Member
    Felix
    Las Vegas
    2017 MGM 4x4 OR Tacoma
    BabyBilly and bowpete like this.
  3. Jun 10, 2025 at 6:55 AM
    #123
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    @ $25 bucks for four, these are coming in over half the cost of a bag already filled with the desired fluid.
    Do you sell them onsey twosy?
  4. Jun 10, 2025 at 7:37 AM
    #124
    Williston
    Williston Unknown Member
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    Some folks here report some debris (metal fuzz on the magnets and a random curled shaving now and then) in the diff oil when they change it. The consensus is that it's possibly leftovers and metal from the initial machining from when it was made. The magnets are doing their job picking it up. The initial change is important. The CarCareNut guy recommends every 30,000, especially for the first change.
    When I changed mine, I had some trace metal fuzz on the magnets but no shavings or pieces. the fluid looked good in all three with the rear diff looking a little darker, leading me to believe they had been changed in the past. The transfer case fluid looked very good as well.
    I refilled them with Mobil1 synthetic 75w90 gear oil.
  5. Jun 12, 2025 at 3:34 PM
    #125
    mississippicelery
    Yeah, I guess my fear is that I highly doubt it was done prior to my ownership, which means it went 70k miles before being done the first time.
  6. Jun 13, 2025 at 5:08 AM
    #126
    jmneill
    SE
    It will be just fine.
    Unless some outside force, such as water intrusion occurred, the diff will not have suffered any damage from going 70K with factory oil.
    None.
  7. Jun 13, 2025 at 5:42 AM
    #127
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I had mine done at 170,000. I'm at 255,000 now with no issues. Shop told me to bring it back at 300,000 miles.
    Unless you drive in deep water and get water inside the diff's the factory oil will likely outlast the rest of the truck.
    jmneill likes this.
  8. Jun 13, 2025 at 5:44 AM
    #128
    jmneill
    SE
    100%
  9. Jun 13, 2025 at 7:47 AM
    #129
    Williston
    I changed mine at 120,000 not knowing for sure if it had ever been done previous. The old fluid looked good so I'm assuming it had been done sometime prior, but no hard records. 25,000 miles later, it is still as quiet as it was before I changed it.
    I wouldn't worry about it. Changing the gear oil in all three units isn't going to make things worse. If you're upgrading to synthetic oil, it's icing on the cake. :proposetoast:
  10. Jun 13, 2025 at 10:27 AM
    #130
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    At high milages you might also want to change the rear diff breather just in case or abandon entirely and do an open breather mod.
    mississippicelery likes this.
