Differential fluid weight when towing
Discussion in 'Towing' started by 1 Limited Toyota, May 6, 2023.
  1. May 6, 2023 at 11:35 AM
    1 Limited Toyota
    1 Limited Toyota [OP] ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    What diff. fluid weight do you prefer to use to tow with? (75w90, 90w or 75w140)
    Do you prefer synthetic like Redline MT90 (GL4 75w90/140) over O.E.M. (GL4 90w)?
  2. May 6, 2023 at 11:39 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    I run 85W-140 conventional myself. I buy Torco RGO. In my old Nissans with basically Dana 44 rear axles, it did not leak past the axle seal in the exact same environment where 75W-140 full synthetic did leak. I think it treats the seals better or something. After 20K or so miles in my Toyota, it looked brand new when drained for regear.
    Just my 2c. No axle is that picky, I just use what I know. Many here run any viscosity in conventional or synthetic and have 0 issues, towing or not.
    Nessmuk likes this.
  3. May 6, 2023 at 11:46 AM
    Clearwater Bill
    Billy
    Largo Florida
    What does the owners manual suggest?
    Usually a good guide.......
    Sprig likes this.
  4. May 6, 2023 at 11:47 AM
    1 Limited Toyota
    California
    08 XRunner
    I'm trying redline syn 75w140. I am rethinking that for 75w90. So does the syn. have a reputation for leaking past seals?
  5. May 6, 2023 at 11:50 AM
    BLtheP
    Plano, TX
    I doubt it in a Toyota diff, Toyotas have a much better axle seal design than the type of design my Nissan D44’s used. I just used that example as a reason why I like to run what I run.
    For towing I would stick to a 140 myself.
  6. May 7, 2023 at 7:20 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Ain’t going to make any difference whether you use synthetic or not or what brand you use. Just use the weight specified in the owners manual.
  7. May 15, 2023 at 10:40 AM
    Tacoma Rant
    Tacoma Rant I can’t be good all the time.
    Wisconsin
    2023 Tacoma TRD Sport Electric lime
    Stock is fine. No need to overthink it
    clownkillerloaf likes this.
  8. May 15, 2023 at 9:42 PM
    1 Limited Toyota
    California
    08 XRunner
    O.k. went to RedLine 75w140 synthetic in differential, RedLine Mt 90 synthetic in transmission, Costco 5w30 synthetic engine oil.engie was flushed with Liqi Moly pre oil change. All fluids had 10% Lucas added.
    This XRunner has 145k on the odometer and was a tow behind a motor home vehicle a large part of its life. Its a vrty tight vehicle, like new in many ways. It did have the somewhat typical hard shift into 5th gear. Its a whole different shifting vehicle now!
    This is a new to me truck and rhe one and only fill up showed 14 mpg. I know that seems on par but we'll see
  9. May 15, 2023 at 9:54 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    X runner is a 5 lug V6?
  10. May 16, 2023 at 5:59 AM
    1 Limited Toyota
    California
    08 XRunner
    Yes
