Differential fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Diabl0, Oct 9, 2022.
  1. Oct 9, 2022 at 5:00 PM
    Diabl0
    Diabl0 [OP] 2005 TRD Off Road DC SR5
    Tim
    Massachusetts
    2005 TRD off Road DC SR5
    AUCar Android Stereo Bluetooth Katskin Leather Soft Bed Cover Dual kicker comp s10’s Bull bar Euro headlights Black grill Clutch bypass switch Alpine 6.5 and 6x9 speakers Kicker Subaru Tweeters Diamond floor mats Dick Cepek DC2 Wheels Toyo Open Country ATII Tires Black Aftermarket Grill Rhino lined Tube Side Steps Back up Camera
    How often do you change your differential Fluid? Valvoline told me ever 15,000 mile. I don’t know when it was changed last but I put about 10,000 on it in a year and I changed it with an oil change.
  2. Oct 9, 2022 at 5:02 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    every 30,000 for me with synthetic gear oil.
  3. Oct 9, 2022 at 5:04 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    TOMB and AJKlug1 like this.
  4. Oct 9, 2022 at 5:06 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    @30 k miles.
  5. Oct 9, 2022 at 5:17 PM
    Heyyo_Friday
    Heyyo_Friday Circle driving enthusiast
    Derek
    Dfw, texas
    2020 tundra 1794
    Rays valve stem caps
    I've done 30k changes as Toyota recommends. I do a bit of towing and backing jetskis into water. Guess it comes down to usage.
    TOMB likes this.
  6. Oct 9, 2022 at 9:36 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Me? Around 50k or so.
    But 30k is better, and that’s probably what you should stick to.
  7. Oct 9, 2022 at 9:51 PM
    TnShooter
    Deogee
    STOCK
    Or never if you’re like most people.
    I’d venture to say, 75% or more differentials are running on “lifetime” fluid.
    Toyota made it easy. They gave us a drain plug.:)
    Dm93 and 10thMTNgrunt like this.
  8. Oct 9, 2022 at 10:17 PM
    Bishop84
    Bishop84 Well-Known Member
    Every 10-15k is nuts. 30 min, 60 max.
    Toyota diff's don't fail. Just use what ever GL5 you want.
  9. Oct 9, 2022 at 10:45 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    30K or whenever I have done a re-gear or a locker.
    Getting ready to step up to 4.56 gears and new oil.
  10. Oct 10, 2022 at 12:29 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    There are many thoughts on this topic and even if many never do change the rear (and in fact front diff and xfer) they can fail due to overheating damage or simply wear from heavy towing, payloads, older sloppy bearings, the front pinion crush sleeve loose, and/or a biggie is gear shock/instant loading offroading. I had to do a full bearing change after heavy towing. Then as nearing 200k offroad on steep rocky area chipped the stock 3.73 OEM ring and pinion on heavy throttle as rear hopped then got traction and that was it. So, we will see how the full rebuilt rear holds up in the future. Diff oil was nearly new on the last.
    The bottom line is yes change it based on use/heat/age/mileage to lessen the chance of failure but it can still occur.
    When/if you change it look at the metal flakes in it due to gear/bearing wear and you realize that new/clean fluid can only help delay time to failure and lessen seal damage.
    That is why Toyota has a maintenance schedule based on normal and heavy use. In fact, the times and mileage have gotten longer due to better quality parts/fluids.
  11. Oct 10, 2022 at 3:58 PM
    jstanley
    jstanley Well-Known Member
    Central TX
    2013 TRD Sport 4x4 Pyrite Mica.
    OTT, OME, Dakar, Eaton rear locker, camper shell, Konig Six Shooters and 33" Wildpeak tires, Pelfreybilt front bumper and skids
    At 20k after new gears mine was pretty dark, the transfer case oil still looked new. Will probably reduce to 15k for future changes diff changes.
  12. Oct 10, 2022 at 4:30 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    I do all 3 front diff rear and tranfer case every 60k kms ish when ever I have time with 75 w 90 and I use 4wd drive every day.
  13. Oct 10, 2022 at 4:32 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    60k is plenty often enough with regular driving.
