Differential fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wayne TOYota Tacoma, Jul 14, 2023.
  1. Jul 15, 2023 at 5:12 AM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    HandOfGod likes this.
  2. Jul 15, 2023 at 6:20 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Yes, the squeeze bags are the sh!t.
    The diffs aren't picky. Pretty much and GL5 will work fine, in the 75-90 weight.
    If you can't find the crush washers and just want to do it this weekend, Teflon tape on those plugs works pretty well.
  3. Jul 15, 2023 at 11:13 AM
    blue_runner
    blue_runner Well-Known Member
    Texas
    2007 PreRunner
    Would anyone happen to have a part number or link to the crush washers?
  4. Jul 17, 2023 at 12:58 PM
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    Instead of starting a new thread. Just curious if most people are using full synthetic instead of the standard for their gear fluid? I’m changing both my differentials and transfer case. I see many are using 75-90w as it seems 75-85w is not common.
  5. Jul 17, 2023 at 1:42 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    It probably doesn’t really matter as long as you change it at the recommended interval.
    I just used Mobil 1 75-90 synthetic. Didn’t notice any difference from what was in there from factory.
  6. Jul 17, 2023 at 1:47 PM
    oldtimertoyota
    New Mexico
    Thank you, I still ended up starting a new thread as I think I was most curious about using synthetic, I’m older now and change is hard for me but if it works better then I made need to change. I appreciate you letting me know that it’s worked good for you!
    spitdog[QUOTED] likes this.
  7. Jul 17, 2023 at 2:07 PM
    spitdog
    No problem, I’m old also. Plenty of info on this site for us to keep our trucks in good shape and save some money from SS checks.
  8. Jul 18, 2023 at 9:57 AM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    https://www.ebay.com/itm/201661605205
    The middle two are for the transfer case.
    Copper is front diff drain, and the three identical smaller ones on bottom are for front diff fill and rear diff drain and fill.
    blue_runner[QUOTED] likes this.
  9. Jul 18, 2023 at 10:54 AM
    TXBoss
    TXBoss Well-Known Member
    DFW
    2009 & 2015 TRD Sport
    Mobil 1... cut the tube to open it up a bit more and it'll flow pretty well.
  10. Jul 19, 2023 at 5:34 AM
    davep2012
    davep2012 Well-Known Member
    Dave
    2012 Silver Tacoma
    Weather Tech floor mats and Marathon Seat Covers
    -Correct me I'm wrong, but to get the bottle angled enough to pour into the rear diff, you have to drop the spare tire?
  11. Jul 19, 2023 at 8:13 AM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
  12. Jul 19, 2023 at 9:18 AM
    TXBoss
    DFW
    That's correct... but it gives me a bit more room to work, and doesn't take that much more time.
    May give the squeeze bags a try if it's available with Mobil 1.
  13. Jul 19, 2023 at 10:33 AM
    HWI
    HWI Well-Known Member
    North Florida
    2015 Tacoma TRD Off Road
