differential fluids?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by little bear, Apr 2, 2018.
  1. Apr 2, 2018 at 7:37 AM
    little bear
    little bear [OP] Well-Known Member
    Barry Hobson
    Canadian, Texas
    silver streak 2017 Tacoma trd sport 4dsb 6sp MT
    Black badges, TRD pro grill, clazzio seat covers, falken wild peaks AT3W 265 70R17, Fuel Trophy wheels, taco tunes 10" sub and Jl Audio all around speaker upgrades, dynamat doors and interior, Meso's interior lights, gasshole, waterproof led bed lights, headstrong progressive leaf pack, bilstein 5100's with OME 887 coils, ecgs bushing, nfab nerf bars, cbi t3 aluminum bumper
    My wife recently purchased a 2015 4dr short bed 4x4 6cyl TSS tacoma.... thats what she wanted so thats what she got- the dealer didn't have the books and info on it yet so I am clueless how much the front and rear differential takes in terms of fluid- anyone got that info or can point me in the right direction? Mobil 1 75-90 is what I am planning on doing- she has the auto transmission so not sure I want to mess with the transfer case but if I did would you put 75-90 in there also? And if so how many quarts does it take?
    Thanks for your time
    1Shifter likes this.
  2. Apr 2, 2018 at 7:48 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Transfer case is that same Mobil 1 its easy to do. Just under 6qts, for rear tc and front. Might as well do the u joints !
    Congrats on the truck
  3. Apr 2, 2018 at 7:55 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
  4. Apr 2, 2018 at 8:02 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
  5. Apr 2, 2018 at 10:04 AM
    little bear
    Barry Hobson
    Canadian, Texas
    thank you for this place and thank you for what you guys/gals bring to it.... thank you thank you thank you
    jkowal20 likes this.
  6. Apr 2, 2018 at 10:09 AM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    I would buy 7 quarts to be safe if changing all 3 gear boxes. I have a 4cyl 5-speed, though.
    Started off with 6 quarts, but ended up buying 8. Doesn't hurt to have a little extra in case chaos should ensue while wheeling.
  7. Apr 2, 2018 at 10:49 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    IIRC the manual needs a different type of oil for the transmission
  8. Apr 2, 2018 at 10:57 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Transmission (auto) uses 13 quarts of Toyota WS. Its completely sealed off and seperate from the transfer case.
    Front diff = 1.6quarts
    Transfer Case = 1.4 Quarts
    Rear Diff = 3
    Order 6 quarts of Mobil 1 75w-90 from pepboys ebay store and it is gonna be the cheapest (free shipping over 35$)
    https://www.ebay.com/itm/Mobil-1-Sy...107943&hash=item2598b47b1b:g:ezAAAOSwpw1ab0C~
    dirty deeds and TacoCat like this.
  9. Apr 2, 2018 at 10:58 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    As others have said, 75w90 in the front and rear diffs and tcase. Get a hand pump, especially for the front diff. If the tranny is an auto, there is a write up on here somewhere on how to do it but you could always have the dealer do it. I think the manual says 100k on the auto tranny but i would do sooner.
  10. Apr 2, 2018 at 10:58 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
  11. Apr 2, 2018 at 12:02 PM
    dirty deeds
    Nick
    Eastern KY
    I did, in case there was a difference in the other drivetrain components. The transmission isn't what needs a refill per the OP.
    Correct. Seems the most popular used is Red Line MT-90 fluid
  12. Apr 2, 2018 at 12:24 PM
    little bear
    Barry Hobson
    Canadian, Texas
    true, my wife's tacoma is a auto tranny but my 2017 trd sport is the 6speed manual...and I am running redline in the transmission :)
    dirty deeds[QUOTED] likes this.
  13. Apr 2, 2018 at 12:55 PM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    https://www.tacomaworld.com/threads/changing-differential-fluid-a-step-by-step-how-to.24545/
    There's a complete how to write up in the Techical Chat forum
  14. Apr 2, 2018 at 1:04 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Just did the front diff yesterday. It's 1.6 qts or until it starts to flow out. You don't need a hand pump for the front if you have a foot long tubing, invert the bottle outside of the LCA and run tubing through the LCA and into the fill hole - tip for adding the final .6 qts is remove .4 qts from full bottle and empty the .6qts into the diff (it will be less messy that way). ID for the drain bolt is 24mm; 18mm for the fill hole. You don't need a pump for the rear either. Don't remember if I used one for the transfer case though - I'm sure you don't. Used Supertech synthetic blend 75-90 for front and transfer case; Mobil 1 75-90 full synthetic for the rear diff.
    MolonLabeTaco likes this.
  15. Apr 2, 2018 at 2:28 PM
    Pork Chopper
    Pork Chopper Well-Known Member
    Dallas, TX
    07 DC 4x4
    Toyota recommends not changing the auto trans fluid and calls is something like "life service," meaning life of the part. I started to get some hard shifts and slips into 5th after some long/hard towing through mountains twice. Had the dealer change the fluid and it went away. :fingerscrossed:
  16. Apr 2, 2018 at 2:43 PM
    Chuy
    Lakeside, CA
    Silver Taco
    @Pilot Mike
    They recommend a full flush at 60K if vehicle meets severe service usage - towing, off-roading, idling (taxi), etc... And our trany's are not completely sealed; all auto trannys have vent tubes to allow for the expanding/contraction of ATF as it warms up. All fluids accumulate contaminants and lose their additive package as the miles pile on. We should be flushing the ATF out of our trannys by 100K if not at 60K, or you do a drain/refill every 30K. That's, if you value your tranny.
  17. Apr 3, 2018 at 9:36 AM
    Pork Chopper
    Dallas, TX
    07 DC 4x4
    That was my perspective and the reason I took it in for new fluid, common sense told me it needed to be changed. Not every dealer had the "pump/machine" to perform the flush, so I had called many dealers and almost every one questioned me as to why I wanted it changed. Then they tried hard to discourage me from doing it and stated "fluid is the life of the trans and should never be changed, " but I demanded it be done anyways. I had it performed twice by separate dealers in different states and that was always the reaction/answer I got, so I assumed that was the standard procedure.
  18. Apr 3, 2018 at 9:38 AM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    Do you pilot for PHI?
  19. Apr 9, 2018 at 9:41 AM
    OldandSlow
    OldandSlow Well-Known Member
    Andrew in Austin
    Austin, TX
    2015 Tacoma Access Cab - 2.7, 5 speed, 4x4
    Not much on mods - Leer 180, TRD wheels, Mobtown sliders, rear hitch, helper springs on the rear
    Dumb question - Is there a reason why Toyota started specifying LF 75W, part # 0888581080 gear oil for the 3rd Gen Tacoma transfer case versus 75-90W, which was used up until the 2015 model year?
