Differential Front & Rear Fluid
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FordTrax, Mar 10, 2023.
  1. Mar 11, 2023 at 1:35 PM
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    Doesn't matter. The quality of the Amsoil will do better in cold than basically anything else.
  2. Aug 10, 2023 at 7:58 AM
    Sandthemall
    Sandthemall Well-Known Member
    Sandamal
    2023 TRD OR MT
    I changed my rear diff oil at 1500 miles out of ‘shear’ curiosity. There was a 1/4” thick layer of grey sludge on the drain plug magnet with plenty of metal metal shavings. Replaced with Amsoil 75w-90. Will do the next change at recommended interval.
    Bought the truck at a dealership 250 miles away. But I did two 20 minute in-town runs with an hour cool down after each one before taking the highway back home. Drove mostly under 60mph. Differential does not howl…quiet as a mouse. I intend to hit 300k miles with this truck. I’ve had an F-150 rear end start howling at 60k…it was the stout 9.75” diff but I took to the freeway right off the dealer lot.
  3. Aug 10, 2023 at 3:16 PM
    Road Bull
    Road Bull Well-Known Member
    WA
    2022 Tacoma TRD OR; 2002 4Runner
    Do our 3rd gens come from the factory with synthetic in the diffs?
  4. Aug 27, 2023 at 12:50 PM
    bcmbcmbcm
    bcmbcmbcm Well-Known Member
    Brett
    22 Barcelona Red TRDOR 6MT worth the wait !! Hang in there !!
    So many threads on this but I think this is the most recent. Seems consensus is any synthetic 75-90 in the diffs, 1 qt Japanese Liquid Gold (Toyota LF) or Ravenol substitute, Red Line GL4 MT 90 in manual trans.
    I am about to DYI. Anyone know what the 'easiest' way to refill are? Those 'flexi' bags 75-90 comes in? What about getting oil out of the can and into the T Case?
    Is there a decent transfer pump that wont fail and wont cost a ton either?
    Last time I did this was on a Dana 60 in a 1970 F250 Highboy 1992 in the dead of winter.
  5. Aug 27, 2023 at 1:15 PM
    2019 TRD Off Road
    Amsoil flex bags are great. They’re a similar price to any other synthetic like Valvoline.
    D.A.S. Taco and shakerhood like this.
  6. Aug 27, 2023 at 3:51 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    85-140 conventional here too. No whine runs smooth and quiet.
    BLtheP likes this.
  7. Aug 27, 2023 at 9:52 PM
    Sandthemall
    Sandamal
    2023 TRD OR MT
    Flex bags were great until the hose/spout connection disintegrated on me. Had to hold the bag’s spout into the fill hole and that was so messy. Always a little left in the bag so I’m gonna try the Slippery Pete pump next time. The rear diff and transmission refills were otherwise very easy to do.
    I used Amsoil 75-90 and diff is quiet. “Shhhh, hear that?” “Hear what?”…”Exactly!”
    I must say: Redline MT90 does make the shifting much smoother…I mean, really smooth. I know it sounds like hyperbole…but it’s true. The most noticeable ‘upgrade’ done to the truck so far.
  8. Aug 28, 2023 at 11:55 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    they replaced my rear differential at 29k miles due to "excessive bearing clearance". changed diff fluid at 500 miles with amsoil severe gear 90 weight. not sure if it's related to the fluid though or just bad setup from the factory. never towed or carried any heavy loads either.
  9. Aug 28, 2023 at 3:05 PM
    Sandthemall
    Sandamal
    2023 TRD OR MT
    Very sorry to hear that. No way to know for sure what happened. I doubt it was simply the fluid change. Most damage to the bearings or rear diff probably happens with excessive heat during the first 100-200 miles. It could also have been defective from the factory as you mentioned. I had a 1993 Toyota that I never babied, drove it from New Jersey to San Jose towing a 12ft. trailer. That diff was as quiet as a mouse and did 108k before I sold it. I changed my current Toyota rear diff gear oil to Amsoil 75w-90 Sever Gear oil at 1400K miles...fingers crossed...but not going to worry about it.
    D.A.S. Taco likes this.
  10. Aug 28, 2023 at 4:28 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Ravenol
  11. Sep 19, 2023 at 7:02 AM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    What would a reasonable intervals be for changing the gear oils in the
    Differentials and transfer case. I'm at 28,000 miles now. I see some say 30,000 miles some say longer. I mostly drive on the roads, nearly no Off-roading and tow a 1500 pound pop-up afew times a year. My usage isn't in pushing the truck too much that often. With winter coming and no Garage to work in doing it myself at 30,000 when that comes around is not gonna be fun. What interval do most of you change it at?
  12. Sep 19, 2023 at 7:19 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I did the initial change at 30k, was black and gross. Changed again at 60k and it looked brand new. I’ll do it again at 160k.
    Once you get the nasty break in fluid initial fill out and put in a high end synthetic you can almost forget about it. That’s my opinion.
    Jaredius and Taco_mike73 like this.
  13. Sep 19, 2023 at 7:20 AM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    i changed my diffs at about 15K because i met the requirements outlined in the manual. the fluid wasn't bad looking and there was not much build-up on the magnetic plugs. based on that, i would feel comfortable going to 30K miles between changes especially if most of what i did was on-road and not hauling or towing.
    i recently changed the MT fluid at 25K miles. it did not look bad either. t-case fluid looks Ok and was not changed although i have a can of fluid from toyota and may do it if i get a pump.
    regarding the diff and MT fluid, i used amsoil severe gear 75W-90 GL5 in the diffs and manual transmission 75W-90 GL4 in the MT. it made no difference whatsoever in noise, felt performance or shifting. i would feel comfortable using any brand provided the weight and GL rating are what is recommended.
    Taco_mike73[QUOTED] likes this.
  14. Sep 19, 2023 at 7:36 AM
    Taco_mike73
    York, PA
    I have an Automatic trans so that has different needs. I will have to just find a place to work indoors or do it before it's too cold to work outside. I assume that Valvoline or any synthetic 75w90 I can buy local or on Amazon is good enough for the front and rear. I acquired some Redline MT-LV for the transfer case which is one of the substitutes that has been said is quite acceptable and less expensive. MT-LV is GL4 also. I'm assuming that if I have the TRD skid plate that has to come off to access the front Diff and transfer case.
    Amorak likes this.
  15. Sep 19, 2023 at 7:42 AM
    #35
    Taco_mike73
    York, PA
    So the Factory fill is most likely not Synthetic gear oil I'm guessing.
  16. Sep 19, 2023 at 7:49 AM
    #36
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    It is. Doesn’t mean it doesn’t get dirty or get metal particles in it off of a new diff.
  17. Sep 19, 2023 at 8:07 AM
    #37
    Sharpish
    Brian
    No idea, but it get pretty torched in the first 30 000 as the diff breaks in. After the diff is completely broken in, aside from possible water contamination, a fresh fill of premium synthetic will last a long long time.
  18. Sep 19, 2023 at 8:15 AM
    #38
    Taco_mike73
    York, PA
    Well that's helpful. I will try to do them as close to 30k as possible. nice to know I can extend it with quality oils after and it will stay cleaner.
  19. Sep 19, 2023 at 8:38 AM
    #39
    bcmbcmbcm
    Brett
    Your post prompted me to change mine at 15K miles. I had the sludge and plenty of metal shavings on the magnet too. It is so easy and cheap to DYI. I lowered my spare for a little more access.
    I am not sure if the sludge and metal actually reduces longevity (plenty of diffs spinning 200K with OEM fill), but common sense tells me it is good to get it out. I used Valvoline flex fill bags I just bought on Amazon and new crush washers. Nothing super exotic. Seems to me that an early initial change to get the crud and metal out is good but then settle into a normal interval.
    clownkillerloaf likes this.
  20. Jan 2, 2024 at 9:42 AM
    #40
    W1JCW
    W1JCW 2016 TRD Sport 4x4
    Bryan, Texas
    Tacoma TRD Sport 4x4
    What is the capacity for the 2016 TRD sport diffs ??
