Differential Gear Oil Change
Discussion in 'Technical Chat' started by Woodcutter, Dec 19, 2013.
  1. Dec 19, 2013 at 4:59 PM
    Woodcutter
    Woodcutter [OP] Well-Known Member
    Missouri
    3.4L V6 96 Taco 4 x 4 SR5
    Ok, thinking of changing the gear oil but I do not know if I have a limited slip(LS) diff? Seems there are two types of oil, one for LS and without LS Any suggestions? Thanks, Woodcutter
  2. Dec 19, 2013 at 5:40 PM
    Woodcutter
    Missouri
    Found my own answer.
    1. Jack the rear wheels off the ground, be sure to chock the front wheels in front and rear to prevent a mishap, place in neutral and spin one wheel clock wise if the other wheel goes the same direction then you have a LS diff.
    2. Tag on pumpkin will have the letter L if limited slip. This advice is according to utube info. Woodcutter
  3. Dec 20, 2013 at 5:25 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Early Tacomas never came with an LSD from the factory. Some came with an e-locker. However, a previous owner could have added an aftermarket LSD unit (as I did).
  4. Apr 21, 2021 at 10:43 AM
    Woodcutter
    Missouri
    Oh, do NOT overfill your differentials this will cause problems, and loss of time, and many $$$$$ to repair.
  5. Apr 22, 2021 at 1:51 PM
    Tacospike
    Two Trucks
    Did this happen?
  6. Apr 22, 2021 at 1:53 PM
    eon_blue
    Azusa, CA
    How do you overfill a differential? You fill it until it comes out the fill port, then close it up. Its literally impossible to overfill lol.
    I'm going to assume he meant it was 'under' filled, because yes that will definitely cause problems.
  7. Apr 23, 2021 at 8:11 AM
    Tacospike
    Two Trucks
    Same
  8. Apr 23, 2021 at 9:21 AM
    eon_blue
    Azusa, CA
    I guess I could see how overfilling it might cause problems, same as overfilling the engine....but I just don't see how one could physically do that to a differential unless you made your own fill port on the very top of it.
    Tacospike[QUOTED] likes this.
  9. Apr 25, 2021 at 1:02 PM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    If you parked on a decline and put in more than what came out you could overfill it.
  10. Apr 25, 2021 at 3:32 PM
    eon_blue
    Azusa, CA
    That's true, hadn't though of that. But parking on level ground is oil change 101 lol. I'm still going with he meant under filled and not over filled...hopefully
  11. Apr 28, 2021 at 5:21 PM
    Fahrenheit
    Fahrenheit Well-Hung Member
    Garth
    NS
    I'm about to do my own as well (elocker), some posts say 3 quarts, others say 3.1, is that 0.1 REALLY that big of a difference? Using Lucas 75w90 synthetic (if that matters)
  12. Apr 28, 2021 at 5:28 PM
    eon_blue
    Azusa, CA
    You just fill it up until it comes out the fill port. That's when you know it's full, however much that takes.
    When you drain it, gear oil is thick and some will always stay behind inside the housing and on the gears, etc. It's impossible to say exactly how much you'll need. Just fill it till it's full
