differential help
Discussion in 'New Members' started by tcarter, Jan 12, 2021.
Hey guys knew to the tacoma formula I was wondering what gear ratio i have in my 1998 toyota tacoma
  1. idk
    0 vote(s)
    0.0%
  2. idk
    1 vote(s)
    100.0%
  1. Jan 12, 2021 at 5:34 PM
    tcarter
    tcarter [OP] Member
    tim
    99 toyota tacoma 2.4 4×4
    Hey guys knew to the tacoma formula I was wondering what gear ratio i have in my 1998 toyota tacoma 2.7 manual 4×4 and on my door jam it had a question mark where the code should be, is this normal on some of these truck? in the process of swapping with a e locker rear end, was wondering if anyone also had a diagram to wiring the diff lock switch. thanks.
  2. Jan 12, 2021 at 5:35 PM
    02hilux
    Planet: EARTH
    Most 3rz are 3.91
    Check your vin label on driver door but they're not always correct.
  3. Jan 12, 2021 at 5:36 PM
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
    If it came with the factory aluminum wheels, more than likely it'll have 4.30 gear ratio
  4. Jan 12, 2021 at 5:37 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
  5. Jan 12, 2021 at 5:38 PM
    02hilux
    Planet: EARTH
    As for the elock wiring, you'll need a DPDT switch or DPDT relay and use a factory RR switch, add an in-line fuse, the actuator pigtail to frame harness, lock light, lots of 18 gauge wire, wire looms, connectors, and more.
    Or spend $200 on a pre-fab harness
    tcarter[OP] likes this.
  6. Jan 12, 2021 at 5:44 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    Welcome to TW
    :hattip: :cheers:
  7. Jan 12, 2021 at 6:03 PM
    tcarter
    tcarter [OP] Member
    tim
    do you by chance have a link to the correct wire harness i need? was trying to figure out how to upload a picture on the sticker on my door jam but not sure how yet, thought it sas weird it had a question mark beside it. ill check out your link to see if i can look it up by the vin. thanks for the replys
  8. Jan 12, 2021 at 6:10 PM
    tcarter
    tcarter [OP] Member
    tim
    think ima just try the spin test amd see what i come up with.
  9. Jan 12, 2021 at 6:23 PM
    02hilux
    Planet: EARTH
  10. Jan 12, 2021 at 9:23 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  11. Jan 14, 2021 at 12:32 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
