differential help
Discussion in 'New Members' started by tcarter, Jan 20, 2021.
  1. Jan 20, 2021 at 6:17 PM
    tcarter
    tcarter [OP] Member
    tim
    99 toyota tacoma 2.4 4×4
    Hey guys i have a fee questions kindof knew to toyota formula, i have a 99 2.7 4wheel drive manual toyota tacoma, i just recently bought a e locker rear end online opened it up and it had the 4.10 gears in it and i know my truck has the 3.58 gear ratio in it so i know i can't just swap the axles, so i was going to go to the junk yard and get a front diff with the same gears to match it, all the 4runners out there have door jam code A03A witch is 4 10 gear ratio to i think not sure, my question is will it work if i get the front diff out the 4runner and out it in my truck with the 410 ratio elocker axle are will i have problems. does it matter if one is 7.5 amd one is 8 but has the same gear ratio? idk confused on it all. thanks
  2. Jan 20, 2021 at 6:21 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
  3. Jan 20, 2021 at 6:40 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  4. Jan 20, 2021 at 6:44 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Welcome to TW :thumbsup:.
    You might want to repost your question here:
    https://www.tacomaworld.com/forums/1st-gen-tacomas-1995-2004.4/
    Those folks know the first gens inside and out!
    Good luck!
  5. Jan 22, 2021 at 4:57 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
