Differential Howl still a problem with the 4th gen. Update: Differential officially cooked
Discussion in '4th Gen. Tacomas (2024+)' started by Teuton, Apr 15, 2024.
  1. Apr 15, 2024 at 5:01 PM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Nope, 3rd. Restating it's nothing new and it may take some of few thousand miles before they really get to experience it.
    abou824 likes this.
  2. Apr 16, 2024 at 9:23 AM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Not the least bit suprised
    abou824 likes this.
  3. Apr 17, 2024 at 10:16 PM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    My 4Runner makes a howl at the front diff if I feather the throttle at 65mph. After 70mph it doesn’t howl anymore.
    I tried to get several of dealers to replace the front diff but of course they couldn’t replicate it.
  4. Apr 17, 2024 at 10:52 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    There's no break in on oem gears
  5. Apr 18, 2024 at 12:28 AM
    TN1000
    TN1000 Well-Known Member
    2018 metallic silver TRD OR
    Work in progress
    What is the howl, why or what causes it? Does it mean something is bad?... I'm having a hard time hearing it on my gen 3 between the mud terrains, the Toyota tik , and the ambient sound of the freeway.
    Lt. Dangle likes this.
  6. Apr 19, 2024 at 4:06 PM
    Teuton
    Teuton [OP] Well-Known Member
    2011 Reg Cab 4x4, 2021 TRD sport, 2024 TRD Sport
    Updated OP with a video
  7. Apr 20, 2024 at 3:25 AM
    Archimedes
    Archimedes Demanufacturer
    Outside the stupid part of Vermont
    23 DCSB TRD OR MGM
    Full-on degenerate heavy metal banjo music
    Sorry, not going through globs of other howl threads, and a very quick search didn't get results...
    Very off beat thought - If some leaning might be towards a harmonic issue, even on the previous gen's, does the beather mod make any difference? If it's definitely COMPLETELY inside the diff housing and a purely metal-on-metal contact thing I assume probably not. But, since a two way breather would change the air pressure inside the diff compared to a sealed breather could this be enough to upset the balance of things in there to help?
    Anyone have / had the two-way and still had the howl?
    ... just trowin' ideas out there...
    ... like maybe bolt on some diff armor to see if it also helps upset the harmonic balance :spending:
  8. Apr 20, 2024 at 3:49 AM
    Smacky2020
    Bristol, VA
    I've had my 2way breather mod since my truck only had 923 mi. Still got the howl eventually so not a pressure issue.
  9. Apr 23, 2024 at 1:25 PM
    Sandthemall
    Sandthemall Well-Known Member
    Sandamal
    2023 TRD OR MT
    If you took the freeway home right off the dealer lot…you’ll risk having some diff noise down the road. Sometimes the truck will have been test driven a few times before you buy…that helps. It doesn’t happen in all cases but probably a contributing factor.
    In my previous life design auto shows for Toyota, we would stage ride-and-drives at the Las Vegas Motor Speedway. Our driving team would take new Toyotas and drive them lightly around the tracks to break them in. When I asked about this, I was told it was not for the engines…but to run the gears in.
    In my own experience getting rear gears replaced in other vehicles, I battled noisy diffs until I learned to take it easy for the first 200 miles. Never had a single issue since…new or rebuilt.
    I bought my 2023 Tacoma 200 miles away and I did several 20 minute in-town drives with one hour cool-downs before driving 50mph all the way home. Rear diff is quiet as a mouse.
    BTW, I took a pyrometer with me just for kicks and that diff got very hot (approaching 280 deg) within the first 100 miles.
  10. Apr 24, 2024 at 11:51 PM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    Not my first new vehicle brake in by far. I drove home starting with 4 miles on the clock. I varied the speed on back roads and even broke in the brakes properly. The diff got louder immediately and peaked at 2500 miles. It takes feathering at 55mph to get the noise now, but it’s there.
    The fluid is at level and clean. I have experienced many brake ins with similar drivetrains in commercial applications where the vehicles are beat on from day one without issue. Smells like poor machining and design period. It’s not the end of the world, just annoying AF.
  11. Apr 24, 2024 at 11:56 PM
    girMobi
    girMobi Well-Known Member
    2020 TRD OFF
    RCI, Martin, Vort and Irken tech
    just slap some KO2s on it and the tread noise will drown it out
    TurboDA6 likes this.
  12. Apr 25, 2024 at 4:31 AM
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    Asking for a friend, if your singing is drowning out the diff howl? :confused::D
  13. Apr 25, 2024 at 6:50 AM
    Tacowrench
    Tacowrench Well-Known Member
    Northern California
    2024 Bronze Tacoma TRD Off-Road
    If the Taco heard me signing, it would start howling...
  14. Apr 26, 2024 at 5:50 AM
    Teuton
    Updated OP
  15. Apr 26, 2024 at 6:01 AM
    #35
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    Any pics of the "burnt oil full of metal"?
  16. Apr 26, 2024 at 6:50 AM
    #36
    Teuton
    no just going of what the dealer told me. I doubt I’ll ever see it.
    BabyBilly[QUOTED] likes this.
  17. Apr 26, 2024 at 7:04 AM
    #37
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    My 2011, i spent 4 years with the dealership trying to get the howl sorted. first they found the transfer case was failing (WTF?) then the rear wheel bearing (ok free bearings are great). they eventually replaced the rear diff for me, and boy, life was sweet. Quiet, problems finally gone. A month later the truck was totalled...
  18. Apr 26, 2024 at 7:13 AM
    #38
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Maybe it's just the video, but I don't hear anything concerning with noise cancelling earbuds on.
    This same old song and dance happened many times in the 3rd gen world. Folks hear the "howl," make a trip or two to the dealer, dealer finally says they found bad oil, or metal in the oil, or whatever else and so they install a new diff. After new diff the problem is exactly the same because it turns out that there was never anything wrong with the first diff. Highly doubt the oil is burned and metal, especially on the magnet, is completely normal. But without getting to see any of that since it's the dealer service department, I'd just let them do whatever they say they'll do and then carry on. If it makes noise afterwards, quit bothering with it.
    BabyBilly and Sharpish like this.
  19. Apr 26, 2024 at 8:21 AM
    #39
    Teuton
    videos never do these type of things justice but trust me it was annoying AF listening to that every time you’re on the highway. I had 2 separate people call out the noise while they were riding in the car.
    The differential howl on the Tacoma has been a topic for the past 20 years. If every single Tacoma had the howl then ok you could maybe pass it off as characteristic. Even if it is a “harmonic resonance” issue, Toyota has had plenty of time to redesign. A lot of Tacomas have the howl and many don’t so obviously there is a design or manufacturing problem somewhere that causes the discrepancy.
    In my case my 500 mile oil is burnt due to excessive temperature which can only happen from excessive friction. I’ve only heard of one other case on the 4th gen with the same symptoms and fix as mine so hopefully the howling diff problem is a thing of the past.
  20. Apr 26, 2024 at 8:43 AM
    #40
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    OEM gears are no different than aftermarket, they are still NEW . Not some magical toyota metal. They set the preload and backlash and that all.
    https://www.motortrend.com/how-to/129-1207-new-gear-set-break-in-or-break-down/
    https://www.yukongear.com/help/faq/...he-break-in-proceedure-for-a-new-set-of-gears
    https://eastcoastgearsupply.com/ft-1479-new-gear-break-in-procedure.html
    https://nitro-gear.com/break-in
    This picture is from a break in change on a new corvette. Didn't take one on my first change. Didn't look quite as metallic but there was definitely a shiny silver sheen to the gear oil. If for the sake of $20-$40 in gear oil you want this stuff eating away at bearings and seals its your DIFF. Is it going to explode at 501 miles no. But over the long run this isn't going to do it any good.
    PDKTaco and Sandthemall like this.
