Differential Howl T-SB-0076-08
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tellico, Aug 8, 2011.
  1. Aug 8, 2011 at 7:05 AM
    tellico
    tellico [OP] Member
    4 cyl
    This TSB was issued to correct the differential howl at speeds 50-70mph. I had the TSB installed on a 2008 Tacoma, and it didn't work. In fact, it made the howl worse. Has anyone experienced the same problem? Of course, I am getting all kinds of BS from the service manager. He even says this whine is really normal for a Tacoma!
  2. Aug 8, 2011 at 10:20 AM
    tellico
    tellico [OP] Member
    4 cyl
    If the whine were normal, why did Toyota issue a TSB? I am communicating with a service rep, but he has the standard BS line.
  3. Jan 18, 2012 at 8:49 AM
    Camshaft
    Camshaft Active Member
    Camshaft
    Saskatchewan
    Tacoma SR5 2.7 2wd
    GROM ipod, usb, 3.5mm input
    I'm having this same howling noise too. For me it happens around 40km/h and is more noticeable in cold weather. Has anyone discovered a way to fix this yet?
  4. Jan 18, 2012 at 10:44 AM
    tellico
    tellico [OP] Member
    4 cyl
    I had three differentials replaced in an effort to fix the whine/howl. None of which worked. Toyota now refuses to do anymore work on the problem. Bottom line is they can't fix it.
    I even complained to the State Consumer Division with no results. State said that they had no power and my only option was to sue them. Which, I cannot afford.
    The howl seems to be getting worse and I guess I'll have to have it repaired someday with my own money even though It is still under warranty.
  5. Jan 18, 2012 at 12:50 PM
    danteisme
    danteisme Well-Known Member
    Vandergrift, PA
    06 DCSB Sport, 96 Integra GSR
    that makes me feel better, because i have the whine and am well out of warranty.
  6. Jan 18, 2012 at 12:56 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    If you had 3 diffs that means its not your diff howling. I would change dealer or get some private tech to figure out what is exactly wrong because current set of people is not doing that great of work.
  7. Jan 20, 2012 at 9:00 AM
    tellico
    tellico [OP] Member
    4 cyl
    I'm thinking about it.
  8. Feb 2, 2012 at 8:17 AM
    danteisme
    Vandergrift, PA
    any update of this situation?
  9. Feb 2, 2012 at 12:28 PM
    tellico
    tellico [OP] Member
    4 cyl
    I don't drive the truck much,25,049 miles. And,I am waiting until spring to have it checked out for something other than a differential. I just drive it to pull my boat.
  10. Feb 2, 2012 at 2:48 PM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2009 4x4 Access Cab, TRD Sport
    Mine is in for a rear axle bearing howl, woo-woo noise. Maybe have a look there on yours....
  11. Feb 3, 2012 at 2:33 PM
    tellico
    tellico [OP] Member
    4 cyl
    Good idea! Thanks!
