Differential identification troubles
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bicycle_Tourist, Apr 7, 2017.
  1. Apr 7, 2017 at 10:36 AM
    Bicycle_Tourist
    Bicycle_Tourist [OP] Member
    Donn
    Corvallis Oregon
    1998 Xtracab 6v 4x4
    Hi Everyone,
    I now own a 1998 Tacoma V6 4wd XtraCab with an Open Differential. Great truck so far. However, I live in Western Oregon and during our last ice storm I began wish that I had some sort of locking rear differential. Because of the truck's age I don't want to get carried away cost wise. So far the most interesting prospect looks to be the PowerTrax No-Slip Locker. These devices are specific to a given differential. I know of two possible differentials for that year 7.5 inch / 27 spline and an 8 inch / 30 spline
    While I would be VERY interested in hearing from any of you who have had experience with any aftermarket locker, my current problem is figuring out which differential is installed on my truck. The VIN sticker on the driver side door jamb is supposed to tell me which differential I have. But the place where this is normally specified only contains a question mark (?). I showed the vin sticker to the local Toyota dealer and they told me that the only way that they could identify my differential would be to take it apart.
    So here is my question (finally!): Did they always use use the 8 inch / 30 spline unit with the V6 motor?
    Thanks!
    Donn
  2. Apr 7, 2017 at 10:43 AM
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
    Yes as long as no other owners have changed out the rear diff before.. I believe All 1st gen 4WD Tacoma's rear diff's are 8", and the front diff's are 7.5"
  3. Apr 7, 2017 at 10:57 AM
    98 Tacoma 4x4
    98 Tacoma 4x4 Well-Known Member
    NE Oregon
    98 Tacoma SR5 4x4
    Actually the 1st Gen Tacoma V6 4x4 came with either the usual 8.4" open differential, or the TRD 8" e-locker rearend.
    Can you take a picture of your door jamb sticker and post it?
  4. Apr 7, 2017 at 10:58 AM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
  5. Apr 7, 2017 at 11:03 AM
    98 Tacoma 4x4
    NE Oregon
    98 Tacoma SR5 4x4
    The Non-elocker diff is still considered an 8" rear diff, but it's called the 8.4" diff because of the larger diameter bolt pattern on the diff.
    Here is an easy way to tell;
    4cyl/V6/E-locker has a dome-shaped cover. Diff uses 8mm studs with 12mm nuts.
    T100/Tundra/non-TRD Tacoma has deeper, blocky cover to accommodate the bearing truss. Diff uses 10mm studs with 14mm nuts.
  6. Apr 7, 2017 at 12:03 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    There is an even easier way to tell the difference. Its the location of the grain plug.
    The e-locker diff (referred to as an 8") has a drain plug on the drivers side/bottom of the diff. The non-locker diff (referred to as an 8.4") has the drain plug on the passenger side/bottom of the diff.
  7. Apr 7, 2017 at 5:17 PM
    Bicycle_Tourist
    Donn
    Corvallis Oregon
    1998 Xtracab 6v 4x4
  8. Apr 7, 2017 at 5:26 PM
    Bicycle_Tourist
    Donn
    Corvallis Oregon
    1998 Xtracab 6v 4x4
    Boy talk about fast response! Thanks to all of you who replied to my question! It seems certain that my truck has the 8" non-locker (referred to as the 8.4"). The drain plug is indeed on the passenger side. And the web page link (http://home.4x4wire.com/erik/diffs/#T100-Tundra) also confirmed that. Again thanks very much.
    Although it is pretty doubtful that I might know anything about Tacomas that any of you don't, maybe I will be able to return the favor one of these days. Donn
    pray4surf likes this.
