differential leak!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Marioso, Apr 14, 2010.
  1. Apr 14, 2010 at 4:21 PM
    Marioso
    Marioso [OP] Risueno
    San diego Ca
    2007 Toyota Fj Cruiser
    2005 tacoma 4.0 automatic prerunner...leaking differential 109k miles
    gf at toyota ordered a differential seal, hopefully thats the problem. truck wont get looked at till friday
    whats the worse that could happen?
  2. Apr 14, 2010 at 4:22 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    you could run out of oil, your gears and bearings will starve and you'll need to buy all new shit. do not let that happen.
  3. Apr 14, 2010 at 4:24 PM
    Marioso
    San diego Ca
    damnit! i know that but i meant whats the worse thing that could be causing the leak
  4. Apr 14, 2010 at 4:26 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    I have no idea, are you sure it's a leak? pics would help, if it's coming from the fill hole, it's not a leak, it's just spillage. Have you checked to see that there is less oil in it than when it was last filled?
  5. Apr 14, 2010 at 4:28 PM
    jandrews
    '09 FourDubDee TRD OR
    The *worst* thing that could be causing the leak is an actual broken diff housing, at which point you'd need to replace the whole third member.
  6. Apr 14, 2010 at 4:37 PM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    Where's the oil coming from?
  7. Apr 14, 2010 at 4:40 PM
    Marioso
    San diego Ca
    the oil is kinda everywhere, hard to tell where its coming from definitely not the fillhole though. jeez!!! im worried
  8. Apr 14, 2010 at 5:08 PM
    drew02a
    San Antonio, TX
    Sounds like you should be. You should definitely pull the fill plug and top it off. Then give it a good cleaning and try to see where it's coming from.
    Did you look at the breather on top?
  9. Apr 14, 2010 at 5:17 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    mine leaks too:D
  10. Apr 14, 2010 at 6:41 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    x2. This is what I would do.
  11. Apr 14, 2010 at 9:03 PM
    drew02a
    San Antonio, TX
    That's GOT to be from the breather. Notice it's dripping down from above the fill plug. I hope you took care of that.
  12. Apr 14, 2010 at 9:11 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    ^ No, I'm pretty sure it's in pieces
  13. Apr 14, 2010 at 9:12 PM
    drew02a
    San Antonio, TX
    Did he explode the housing or what?
  14. Apr 14, 2010 at 9:26 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
  15. Apr 14, 2010 at 9:34 PM
    drew02a
    San Antonio, TX
  16. Apr 14, 2010 at 9:37 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    really? why?
  17. Apr 14, 2010 at 9:37 PM
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    Instead of just "topping off" your diff fluid, you should drain it completely and refill it. This was you can measure how much comes out, so you'll know how much you lost already. That will give you an idea of the speed of the leak. You can then add more fluid if necessary before the new seal comes in.
  18. Apr 14, 2010 at 9:38 PM
    drew02a
    San Antonio, TX
    The ring and pinion are notoriously weak. Kinda sucks since alot of people actually use them to offroad.
  19. Apr 14, 2010 at 9:45 PM
    1TUFFTRD
    1TUFFTRD WTF
    06 AC with a skewp
    06 With a Skewp.
    ^^ they said a ring and pinion bolt broke and then tore everything up!
  20. Apr 14, 2010 at 9:46 PM
    drew02a
    San Antonio, TX
    Then yours is a fluke. There is a massive list of people who's gears just broke all on their own. I don't really see how a bolt would ever just come out.
