Differential lock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zrx1100, Apr 29, 2017.
  1. Apr 29, 2017 at 7:10 PM
    Zrx1100
    Zrx1100 [OP] Member
    Georgia
    07 silver taco
    If I don't have the lock button are the wires still in the dash and all I need is to install the switch or do I have to do more
  2. Apr 29, 2017 at 7:12 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    It may depend on what year it is, but I doubt the wires are there. Even if they were, you still have to wire it to an actuator and a TRD offroad differential.
  3. Apr 29, 2017 at 7:15 PM
    Zrx1100
    Zrx1100 [OP] Member
    Georgia
    07 silver taco
    07 Tacoma pre runner six lug I have quite a few open plugs back there this is kinda the first I have looked into it to see
  4. Apr 29, 2017 at 7:17 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    No you would have to swap in a trd Offroad axle.
  5. Apr 29, 2017 at 7:19 PM
    Zrx1100
    Zrx1100 [OP] Member
    Georgia
    07 silver taco
    That's what I needed to know then thanks
  6. Apr 29, 2017 at 7:20 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Sorry man. Getting that locker isn't cheap. If you don't want to swap axles, you could always install an ARB Air Locker. It'll still be expensive though. Best of luck.
  7. Apr 29, 2017 at 7:21 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Welcome to TW by the way
  8. Apr 29, 2017 at 7:24 PM
    Zrx1100
    Zrx1100 [OP] Member
    Georgia
    07 silver taco
    I have always came here for a lot of questions but just now made an account. I love TW saved me countless hours
    DustStorm4x4 likes this.
  9. Apr 29, 2017 at 7:27 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Any thoughts about getting an air locker vs a OR axle and wiring it up?
  10. Apr 29, 2017 at 9:36 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    My personal belief? I would go the ARB air locker. Out of both of the TRD Offroads I've had, both of the lockers failed on me. The first one I had worked a lot but after months of use, it gave out, never to turn on again. The second one (this one) has always been a pain in the ass to turn on. I've only got it to engage twice throughout the years. A good amount of people have had the same problem and the only way to fix it, is to take the actuator apart and reassemble it a certain way.
    b_r_o[QUOTED] likes this.
  11. Apr 29, 2017 at 9:47 PM
    big_jarv
    big_jarv Well-Known Member
    2020 TRD Pro
    This.
    I think mine has engaged 2 or 3 times.
    DustStorm4x4[QUOTED] likes this.
  12. Apr 29, 2017 at 9:52 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Not to sound snarky but are you turning the steering wheel while rolling forward slowly. This gets the diff to walk and you can hear a click when it engages. I had a 2011 trd OR and I was pretty frustrated with the locker until I learned how to engage it
  13. Apr 29, 2017 at 9:56 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    AIR, they disconnect and connect immediately. Also the OR axles are an 8.0 rearend and if you don't have an E locker you can get the ARB Air locker since that rearend is an 8.4.
  14. Apr 29, 2017 at 9:57 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I would hit the button and then do sort of a cone slalom. This would work everytime..
    If you're going straight the wheels are turning at the same rate (obviously) .. remember it's the side gears that lock to the case. They need to rotate at different speeds for lock apparatus to fall into place..
  15. Apr 29, 2017 at 10:00 PM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Correct, but once the switch is hit and it loses air, it doesn't take much for them to disengage. My tacoma ARB's work amazing. My land cruisers factory Elockers I practically do figures 8's
  16. Apr 29, 2017 at 10:01 PM
    big_jarv
    2020 TRD Pro
    I'll have to try that.
  17. Apr 29, 2017 at 10:04 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    So whatever kind of motor tptpta puts in there it doesn't seem very strong. What kind of psi do the air pockets run on just out of curiosity
  18. Apr 29, 2017 at 10:05 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    ..Whatever motor Toyota puts in there...
  19. Apr 29, 2017 at 10:05 PM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Haha I guess it's a weak little bastard. It's not much at all 130 psi I think
  20. Apr 29, 2017 at 10:06 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Air lockers.. sorry big fingers.. giggiddy..
