Differential Lock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wade50, Jun 22, 2021.
  1. Jun 22, 2021 at 10:17 AM
    wade50
    wade50 [OP] Member
    Chesapeake, Virginia
    2013 Toyota Tacoma 4WD 4 Door TRD Off Road
    Total Chaos Bed Stiffener
    I have a 2013 Tacoma Dual Cab TRD Off-Road.
    Is it possible to use Differential Lock while in 4-High/ 4- Low?
    Truck has 280,000 miles and didn't want to try it without asking
    the group first.
  2. Jun 22, 2021 at 10:24 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Stock, you can only use the rear locker in 4low. Use it (on a low traction surface), exercise it to keep the actuator operating properly.
    wade50[OP] and blu92in99 like this.
  3. Jun 22, 2021 at 11:08 AM
    wade50
    wade50 [OP] Member
    Many thanks for the tip.
  4. Jun 22, 2021 at 11:11 AM
    eon_blue
    Azusa, CA
    There is a wiring mod you can do that enables you to lock the diff in 2wd or 4hi as well, with 1st gens it's referred to as the Grey Wire Mod. Not sure what the 2nd gens call it
    wade50[OP] likes this.
  5. Jun 22, 2021 at 11:11 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  6. Jun 22, 2021 at 11:17 AM
    nd4spdbh
    SoCal
    Heres an alternative that i use for the locker anytime mod, way less invasive to your wiring harness
    https://www.toyotanation.com/threads/locker-mod-an-alternative.226409/
    With the only caveat is that it will throw a check engine light if you go over 25mph (or travel x amount of distance). Easy price to pay for not having to chop everything etc just clear with a bluetooth OBD and a phone.
    wade50[OP] and Too Stroked like this.
