Differential Noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by IFGD, Mar 1, 2017.
  1. Mar 1, 2017 at 11:24 AM
    IFGD
    IFGD [OP] Well-Known Member
    Ian
    Raleigh, NC
    2001 Regular Cab 2.7L
    I've searched old threads for something similar with absolutely zero luck.
    Truck is a 2001 SC PreRunner 2.7 with 49k miles. When I'm accelerating, all is quiet. When I'm off the throttle, all is quiet.
    There is a sweet spot where my differential whines. I'm assuming when there is no positive or negative force on the gears they're just all loose in there causing them to make noise.
    This led me to believe there might be play in the diff. I got under there and could turn it about a quarter of an inch.
    Any suggestions on what I need to do about this?
  2. Mar 1, 2017 at 11:28 AM
    Patrick1046
    Patrick1046 Well-Known Member
    05 AC Long Bed - 16 DC Short Bed - 16 4Runner
    Have you ever replaced the front needle bearing? Common weak spot on the trucks dating back to 1995.
  3. Mar 1, 2017 at 11:29 AM
    IFGD
    Ian
    Raleigh, NC
    No. Can you explain what that is?
  4. Mar 1, 2017 at 11:32 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    It's not 4wd so not front needle bearings. Could be a rear axle bearing on it's way out.
  5. Mar 1, 2017 at 11:36 AM
    IFGD
    Ian
    Raleigh, NC
    It's made this noise for the past year. Hasn't gotten any worse, but it's annoying as hell.
    It doesn't sound like a bearing going bad. It's more of a gear sound than a howling bearing noise. Could a bad bearing could cause the gears to be out of alignment and thus cause the play in the gear set?
  6. Mar 1, 2017 at 11:41 AM
    Bishop84
    Bishop84 Well-Known Member
    Most differentials will make that noise if you slightly load it on coasting, I can make 2015's do it. It's when it gets to the point where the noise happens all the on and off the throttle it becomes an issue.
    The play you tested is backlash, which can cause the noise. But the real concern with a noise like that is the pinions movement laterally. It's normal for a pinion to move slightly up and down when you push up against it (unloaded in the air) but if the play is excessive the pinion bearing itself is the cause of the noise. It's hard to gauge this and experience goes a long way.
    Either way a pinion bearing/back lash crush sleeve replacement is a pain in the ass. I'd wait for it to get worse personally.
    My 2 cents :)
    Xbeaus likes this.
  7. Mar 1, 2017 at 11:51 AM
    IFGD
    Ian
    Raleigh, NC
    Thanks for that.
    I'm not quite following what you mean when you say it's normal for it to move up and down. When I turn the prop shaft by hand back and forth I can actually hear the gears hitting each other. Is that normal?
  8. Mar 1, 2017 at 11:57 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Mine does that too and so does another members on here that I hang out with.
  9. Mar 1, 2017 at 3:35 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Some backlash is necessary. A 1/4" of movement is not excessive. But you might wanna keep an eye on it to see if it increases.
    How long has it been since the 3rd was serviced? How many miles on that gear oil. If you are unsure, do the oil change. The diff drain plug is magnetic and will collect any debris (metal shavings) floating around in the oil. Chunks would indicate a problem. Some metal paste/cream stuck on the drain plug is normal.
  10. Mar 1, 2017 at 3:47 PM
    IFGD
    Ian
    Raleigh, NC
    I had the diff oil replaced about 3k miles ago. I'm beginning to think this is one of those "truck noises" that I just need to get used to.
  11. Mar 1, 2017 at 3:58 PM
    wamego
    wamego Well-Known Member
    2002 Tacoma 2x4 TRD SR5
    Could be coming from the carrier bearing. See if you can move it around with your hands.
  12. Mar 1, 2017 at 4:07 PM
    IFGD
    Ian
    Raleigh, NC
    I don't have a carrier (center support) bearing.
