Differential Oil Change Interval?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by plaidad, May 27, 2014.
  1. May 27, 2014 at 5:19 PM
    plaidad
    plaidad [OP] New Member
    09 SR5 Access Cab 4cyl 4wd
    I am trying to find out how often I need to change the oil in my differentials and transfer case. I have a 2009 without limited slip. When I look through the service intervals on the Toyota website, I see that the limited slip oil should be changed every 30,000 miles. I can't find anything on the non-limited slip. Does anyone here know for sure?
    Thanks
  2. May 27, 2014 at 5:25 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Same. 30K for the rear without the true LSD and I believe 60k for the front (if you have 4wd).
  3. May 27, 2014 at 5:46 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    if you dont know when you changed it last... change it... its going to be NASTY,
    Changed mine at 6k miles on my new truck, and it was gross due to break in.
  4. May 28, 2014 at 4:59 AM
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
  5. May 28, 2014 at 5:07 AM
    vram74
    vram74 Well-Known Member
    05 Prerunner SR5
    lol, I don't need to hear things like that. Whoever had my truck before took excellent care of it, but the dealership they used apparently never brought up to them to change the diff fluid. It got it first change @ 94k when we bought it.
  6. May 28, 2014 at 8:07 AM
    nd4spdbh
    SoCal
    ^holly jezus.
  7. May 28, 2014 at 8:21 AM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    At that point..."diff mud"
  8. May 28, 2014 at 8:26 AM
    vram74
    05 Prerunner SR5
    I guess all I can do is hope that maybe the guy changed it himself or took it to a shop that didn't report servicing it to carfax. Dealership didn't come out and say "Damn son!" or anything. Just serviced it and let me go.
    If it helps anything, it was probably an easy 94k. Doesn't look like it was ever taken off road and the bed liner never had a scratch until I put one on it.
  9. May 28, 2014 at 9:33 AM
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    It's like oil changes...easy to do yourself, so why have the dealer do it.
  10. May 28, 2014 at 10:01 AM
    vram74
    05 Prerunner SR5
    I am not dumb by any means, but accident prone. This is especially true when attempting new things. Learning new things on something I'm paying for for the next 4 yrs makes me even more nervous about trying it.
  11. May 28, 2014 at 3:19 PM
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    Lol. I'm the same way. Have someone show you how to do it. It's idiot proof.
    Park on level ground
    Take out fill plug
    Take out drain plug
    Wipe off drain plug (check for larger shavings to predict possible problems)
    Put drain plug back in
    Fill until it starts to come out.
    Replace fill plug
    If you can change your oil, you can change your diff fluid.
  12. May 28, 2014 at 3:28 PM
    fau8823
    fau8823 Well-Known Member
    Tom
    Hampton Roads, VA
    2010 Tacoma Sport 4x4
    Tint-20%, Kenwood 2 meter radio, firestik 2 meter antenna on a BAMF tailgate mount, Extang Solid Fold , Pioneer bhs-3500 HU, clazzio leather seats, Scangauge II
    I tried changing mine last week, but couldn't get the damn pill plug off. I didn't want to strip the bolt (came off a couple times while torquing it), so I stopped. I sprayed it with wd-40 and that didn't help. Any other ideas???
    I'm think about waiting until September and taking it to someone to avoid stripping the bolts. My inspection is due then and i hardly drive my truck (have a work vehicle I take home). I REALLY don't want to pay someone to do it though.
  13. May 28, 2014 at 4:49 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
  14. May 28, 2014 at 7:01 PM
    vram74
    05 Prerunner SR5
    Couple Q's: Since I'm operating on the assumption that my diff fluid wasn't changed at all before I got the truck, would it be advisable to Chang the fluid again in a few thousand miles due to gunk buildup?
    is it normal to have some metal shavings?
  15. May 28, 2014 at 8:10 PM
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    It wouldn't hurt anything to change it after a shorter interval. Check it at your next oil change and see how bad it is. If you need to change it, do it. If it's okay, change it around 20k.
    Small metal shavings are normal. Larger hunks are not. Anything bigger than a peice of rice, I would be concerned.
  16. May 28, 2014 at 9:42 PM
    vram74
    05 Prerunner SR5
    Thanks for the info
  17. May 29, 2014 at 3:50 AM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Where'd the op go? Makes a quick double post, then disappears!
