Differential oil - keep or change?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dacon, Dec 30, 2017.
  1. Dec 30, 2017 at 11:15 AM
    Dacon
    Dacon [OP] 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    TXpro4X4 likes this.
  2. Dec 30, 2017 at 11:17 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I would leave it alone for 30K unless the way you use your truck calls for something better than the standard dino oil (like racing or heavy off roading).
    To me it's just wasted $$$$. But that's my $0.02
  3. Dec 30, 2017 at 11:19 AM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    I changed mine over to Amsoil at 40k.
  4. Dec 30, 2017 at 11:50 AM
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    The OEM fluid is synthetic not dino. I changed mine at 17,000. I am going to wait until 25k to do the transfer case and 30k for the front diff. The fluid was about $100 about $20 more than Amsoil since the Toyota fluid is sold it liters and everything else is sold in quarts. I also replaced the crush washers/gaskets for $5.
    The fluid was black but that doesn't mean anything. The magnet had a decent layer of very fine metal particles. It is possible changing it early helps prolong the diff life by removing those abrasive particles. It really depends on if $100 is a lot of money to you. If it isn't it is pretty cheap insurance and it's an easy job to do yourself.
    BOZOJUICE likes this.
  5. Dec 30, 2017 at 12:04 PM
    AllisFan
    AllisFan Well-Known Member
    On the market as it were
    The magnet holds the particles so they rest of the differential doesn't see them. They can't hurt anything if they are stuck on a magnet.
    10k rear diff oil change is a bit early unless you submerge the rear axle over the hubs often.
  6. Dec 30, 2017 at 12:07 PM
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    If you don't care about the cash or time it takes, I say go for it.
    For me it was relatively cheap piece of mind (https://www.tacomaworld.com/threads...-manual-transmission-6mt-fluid-change.481719/) Toyota didn't have their shit together for the early runs of these trucks but I think it got better.
    OA
    TacomaMike37 likes this.
  7. Dec 30, 2017 at 12:14 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I went with Mobil1 for F&R dif's at 30K. I will do the rear dif again in 30K intervals. The front dif I'm going to wait something like 60K intervals.
  8. Dec 30, 2017 at 1:23 PM
    Dacon
    Danny
    Gilbert, Arizona.
    I might just for the peace of mind. I spend close of $100 a week for smokes...why not for gear oil?
    How many quarts I need for the rear diff?
  9. Dec 30, 2017 at 1:36 PM
    rnish
    Tacoma 2nd gen
    3 plus a little, get 4
  10. Dec 30, 2017 at 1:45 PM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    May as well change your oil every 500 miles while you are at it.
    TacomaMike37 and MannyS like this.
  11. Dec 30, 2017 at 1:49 PM
    su.b.rat
    su.b.rat broken truck
    in a perfect world i would agree with this. but the imperfect world of the 3rd gen fluids had me concerned. so i changed the diff to Amsoil. big deal?
    not really, but what was revealed is that my diff was about 300ml low from the factory. this was around 14k.
    luckily I've had no diff issues. currently 24k
  12. Dec 30, 2017 at 3:22 PM
    Dacon
    Danny
    Gilbert, Arizona.
    Feel any difference from OEM oil to AMSoil in diff?
  13. Dec 30, 2017 at 3:25 PM
    su.b.rat
    i changed all the fluids that visit before getting on the road for a 2 week trip to CO. there was change yes maybe or maybe not from the diff, but i changed MT oil as well, so I'd say it's hard to tell exactly if or how the diff changed... i wasn't having any symptoms before. but the MT was a little smoother especially going into 3rd. used Royal Purple on the MT.
  14. Dec 30, 2017 at 4:24 PM
    Blue_Heeler13
    Blue_Heeler13 Well-Known Member
    Kirk
    North Carolina
    2017 TRD OR 4x4
    I've always changed diff oils in my toyota's at 30k-40k range. If you dont offroad or tow much, i kinda feel like its pointless to do it before then, but to each their own. And i always used Mobil1 products. Never had an issue.
  15. Dec 30, 2017 at 4:48 PM
    Omar RVA
    Omar
    OR
    Different amounts for different diffs, but this is wrong. He should need 4.0 or 4.2 (depending on whether or not he’s driving a stick). I’d get 5 quarts.
    Not sure that this comment adds anything. Multiple people here have had rough diff fluid and plug magnets caked with shit before 10k and even low levels of fluid. OP wants to look after his truck. There’s nothing wrong with that.
    I definitely noticed a difference (mostly in smoothness) but it’s hard to tell why since the OEM fluid for me was in rough shape and likely underfilled from factory. All my research has shown that Amsoil is pretty much as good as it gets as far as performance and change intervals are concerned.
    OA
  16. Dec 30, 2017 at 5:10 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Two things I considered...
    New gears produce a lot of heat. Heat breaks down fluid.
    Thus, every gear manufacturers recommendation for proper break-in and 500 mile fluid change.
    Or...
    Is Toyota 75w85 some kind of super lube, the gears REM, had some kind of factory break-in and/or came filled to the proper level?
  17. Dec 30, 2017 at 5:16 PM
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
    Mine was 1 quart 8 ounces low from factory.
    No leaks and no problems with it other than that.
    over60 likes this.
  18. Dec 30, 2017 at 5:36 PM
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    My rear diff had no oil from the factory and detonated w/less than 500 miles on the clock. Got a new one, my 1st payment refunded and 7yr 100K platinum warranty. Been thinking about changing it soon though.
    shakerhood likes this.
  19. Dec 30, 2017 at 7:12 PM
    OregontoBajaCA
    2025 OR DC iF Max
    My front dif was only 7 ounces low.
    Transfer case was full.
    Perhaps the assembly line was moving too fast for the one worker to keep up with 3 jobs.
    Job #1- Fill transfer case.
    Job#2- Fill front differential.
    Job#3- Truck has already moved to next location on assembly line.
    Oh well...
    Dacon[OP] likes this.
  20. Dec 30, 2017 at 7:46 PM
    bucktowntaco
    bucktowntaco Well-Known Member
    New Orleans
    2017 MGM DCSB TRD Sport
    I changed my rear diff fluid over to amsoil at 10k. The drain magnet was covered in sludge.
