differential oil on 07 taco 4d 4wd
Discussion in 'Technical Chat' started by paquun, Jun 8, 2009.
  1. Jun 8, 2009 at 9:27 PM
    paquun
    paquun [OP] paquun
    calexico ca
    4x4 tacoma
    I replaced the differential lsd oil on my truck. Because the rear end felt like it was dragin when doing a tight turn. I replaced and added the proper amount of additive and the differential oil sold at The toy parts center. The problem got worse. The rear end felt like if the hand brake was on or one of the brake shoes was stuck. Raised both rear wheels and they both moved forward when in neutral, like if the truck had full time posi traction. Took it to the dealer ship and they suggested to add two more of the lsd additive. so far it seems to have solved the problem. So keep in mind 2or 3 additive per differential oil change.
  2. Jun 8, 2009 at 10:41 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    I always used to use 2 tubes of the additive when I had an LSD
  3. Jun 8, 2009 at 10:43 PM
    brianr
    brianr go shit in your hat
    2010 4x4
    BUILT, not bought...
  4. Jun 8, 2009 at 10:49 PM
    brianr
    2010 4x4
    As I outlined in the above link, I used ONE 4oz. tube.
    I have not had a single issue, with 8k miles on the new differential fluid.
