Differential Oil Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Pat Masac, Jun 8, 2010.
  1. Jun 12, 2010 at 4:21 PM
    747
    747 function > form
    1st Gen.
    You bet. Good luck! BTW, I replaced the crush washer the FIRST time I changed the diff fluid (about 50k miles ago); I didn't replace it the SECOND time (about 100 miles ago). If you notice leak/drip post-change, you'll know a replacement is necessary....in which case you can just drain the new stuff into a new (clean) pan, and refill after replacing the crush washer.
  2. Jun 12, 2010 at 5:45 PM
    Pat Masac
    Pat Masac [OP] Member
    Patrick
    Beaumont, TX
    Tacoma V6 2WD
    Thanks for all the advice on the diff oil change. The whole job took me about 45 minutes. The fill plug took a little muscle with a breaker bar and a 15/16" socket, but the drain came out with no problems. The oil was a little dark but looked really clean. The magnet on the drain plug had some fine metal on it but nothing major. The Sta-Lube pump made life REALLY easy. I'd highly recommend dropping the 10 bucks for this if you don't already have on. I flushed mine and plan on re-using it for a transmission oil change. Now, on to my goal of 500k miles! I love not having a car payment- I can't help but laugh every time I see a new GM product on the road with rear lights out. Best, Pat
