Differential Oil Recommendations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Teufel Hunden, Oct 28, 2008.
  1. Oct 28, 2008 at 10:18 AM
    Teufel Hunden
    Teufel Hunden [OP] No Better Friend, No Worse Enemy
    Northern Virginia
    09 MGray DC SB TRD-OR 4x4 V6 Auto SR5
    Undercover tonneau, OEM tow package with hitch, OEM retractable roof rack, Front window tint (legal), WeatherTech FloorLiners, Door sill protectors, Tacoma bed mat, Rear leaf spring TSB, OEM DRL mod, Door edge guards, AFE Pro-Dry S Air Filter, Removed secondary air filter, Smoked LED 3rd brake light, Romik running boards, Go Rhino hitch step, Extra set of D-rings mod, Bed cargo net, TRD wheel locks, OBX sport pedal covers.
    Here are the Tacoma's differential oil recommendations, and filler plug torque specs. The 2008 file covers 2005-2008, and the 2009 file is only for that model year.
  2. Oct 28, 2008 at 10:52 AM
    Joe B
    Joe B Well-Known Member
    Amsoil Severe Gear 75w90 here.
  3. Oct 28, 2008 at 12:23 PM
    hate2work
    hate2work Well-Known Member
    Washington State
    06 standard cab
  4. Oct 28, 2008 at 1:09 PM
    Teufel Hunden
    Northern Virginia
    Once it's time for my first oil change, I'll be switching everything except the transmission fluid to Amsoil also.
  5. Oct 28, 2008 at 1:42 PM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    where did u print of this differential fluid? the problem amsoil is so damn expensive and hard to find.
  6. Oct 28, 2008 at 1:51 PM
    Teufel Hunden
    Northern Virginia
    Here is the website. You have to pay a fee to get access though. If you sign up for the preferred customer program for Amsoil then you will get discounts on everything you purchase, and you can get their entire line of products online.
    www.techinfo.toyota.com
  7. Oct 28, 2008 at 1:57 PM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    ohhhh... I was thinking about geting amsoil, how many miles u going to put on it before u do any oil change? i have the orginal filer that i ordered from Japan, well a va dealer had 3 Denso filter made in japan part 90915 20004 very hard to come by if i go to amsoil I might not do an oil change until like 7500 miles maybe.
  8. Oct 28, 2008 at 2:33 PM
    hate2work
    Washington State
    06 standard cab
    Who knows, maybe by then Amsoil will have something compatible with the WS fluid toyota uses :)
  9. Oct 28, 2008 at 3:02 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i have been using mobil1 75w90 in all my diffs/transfer case for a good while now...good stuff.
  10. Oct 28, 2008 at 5:46 PM
    Teufel Hunden
    Northern Virginia
    I was planning on doing my first oil change at 1500 miles to get rid of the break-in particles that have built up. I'm going to put in Amsoil at that point, probably 0W-30, and then I'm going to do the recommended 5000 mile changes from that point on. You would probably be just fine doing your oil changes at 7500 mile intervals with Amsoil, or any synthetic, but I am a very paranoid person and want my engine to last forever, so that is the only reason I am sticking to the 5000 mile changes.
  11. Oct 28, 2008 at 5:55 PM
    Teufel Hunden
    Northern Virginia
    That would be great! :) I hope they do! Although, since Toyota made it so difficult to change the transmission fluid since you need special tools and have to follow special procedures, I would be hard pressed to be able to change the fluid out myself. The most I could even hope to change is the fluid in the pan, and I'm not even sure you can fill up the transmission with new fluid without a special piece of equipment. I'd have to take the truck to the dealer and ask them to use my fluid instead of theirs when they fill it up, if they would even allow that.
    Also, for those who may want it, I have a copy of the transmission fill procedure here, but will have to wait until to go to work tomorrow to scan it, and then I will post it.
  12. Nov 6, 2008 at 1:09 PM
    Teufel Hunden
    Northern Virginia
  13. Aug 19, 2015 at 7:50 PM
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    Why use amsoil severe gear 75w90 rather than their long life 75w90?
    The severe gear is an EP gear lube. It seems like most of the other lubes people are using like mobil 1 and redline are more like the long life 75W90 (as in not EP gear lubes)?
  14. Aug 19, 2015 at 8:00 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  15. Aug 19, 2015 at 8:29 PM
    Eyedoc2020
    Eyedoc2020 Well-Known Member
    Greg
    DC suburbs
    2012 TRD Off Road
    I have used Redline 75/90 the past 2 times. Seems to be doing the job like it is supposed to. No complaints here.
  16. Aug 19, 2015 at 8:34 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    I probably should make a separate thread for this, but I'll place it in here first. I "think" it's time to replace my rear differential oil considering the truck has 103k miles. I have not a clue as to whether the previous owner has performed the sceduled maintainence or not. Which brand/weight do you guys recommend? Some people recommend synthetic, others say the conventional/standard oil. Also do I need to replace any gaskets or anything? Any help would be appreciated!
  17. Aug 19, 2015 at 8:39 PM
    Blackat
    Blackat Well-Known Member
    Bryan
    Colorado
    99 Tacoma SR5
    TRD Stat, TRD Supercharger, TRD Headers, TRD Cat-back, slight lift.
    I use redline for front, rear diff, manual transmission and transfer case. Change every 30-40k miles, except the front diff. I let that one go longer.
  18. Aug 19, 2015 at 8:41 PM
    badger
    badger Well-Known Member
    07 SR5
    Redline for me, in every gear box.
  19. Aug 19, 2015 at 8:42 PM
    ZachPrerunner
    Southeast TN
    Do you have to order redline or can it be picked up at a local auto parts store? Also, what weight to use in the rear dif. I have an off-road package and as far as I'm aware I don't have the LSD. It does have the locker obviously considering it's a prerunner.
  20. Aug 19, 2015 at 8:43 PM
    HAVVOKK
    HAVVOKK Well-Known Member
    2014 DGAF Long Bed
    Fucking look it up
    So 75 90w? I think I have 75w 115 or something is that bad?
