Differential oil
Discussion in 'Canada' started by darkgohan, May 2, 2011.
  1. May 2, 2011 at 1:56 PM
    darkgohan
    darkgohan [OP] Well-Known Member
    Getting ready to changes these oils [75 w 85 -- 75w90] dino oil,anyone got a place to buy this,wally world didnt carry anything here nor does can tire. 2010 4x4,no lsd required. What are others using?? T Y :)
  2. May 2, 2011 at 1:57 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    I use redline and love it, so does the truck
  3. May 2, 2011 at 2:00 PM
    darkgohan
    Thanks,and where are you able to purchase this from??
  4. May 2, 2011 at 2:05 PM
    darkgohan
    Thanks wolfpack_5150 !! :):)
  5. May 2, 2011 at 2:08 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    OP , check Canadian Tire
  6. May 2, 2011 at 2:14 PM
    darkgohan
    Will try autozone,thanks,Can Tire here was motomaster brand,although they had a few other lines,maybe I should take another look.
  7. May 2, 2011 at 2:27 PM
    OZ-T
    Peter North
    British Columbia
    Hey sorry man , I missed that you had checked Canadian Tire .
    A little bird informed me of my mistake .
    Home Hardware has a suprisingly large selection of automotive stuff in their catalouge as well .
    Good luck
  8. May 2, 2011 at 2:35 PM
    darkgohan
    Thanks
  9. May 2, 2011 at 4:13 PM
    darkgohan
    Found this at Home Hdware,any comments
    • Castrol Hypoy C Gear Oil
    • Exceeds API service GL-5 lubricant for extreme pressure conditions
    • Recommended for applications calling for Ford ESP-M2C154-A and GM 9985290; also Mack GO-H approved
    • Recommended for service fill of all conventional and limited slip differentials in passenger cars and light trucks calling for SAE 80W-90 and API service Gl-5 specifications
    • Exceeds API MT-1 lubricant for non-synchronized manual transmissions used in buses and heavy duty trucks
  10. May 6, 2011 at 12:43 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Im also having trouble getting some along with good manual tranny fluid
  11. May 6, 2011 at 5:03 PM
    darkgohan
    For some reason any follow up answers here have dried up,go figure!! Anyways I was able to get Lucas 75w90 synthetic from my local Lordco by order and it is done,in spite of no one answering my query about Castrol?? Good luck,ask me if you need more info.
  12. May 6, 2011 at 5:07 PM
    JHAirForce05
    JHAirForce05 I'm kinda a big deal
    Justin
    Tacoma, WA
    09 DC LB SP
    Kenwood DDX712 with Nav and rear view cam, Viper 5901 Security System, Kobalt Slim Line Compact Truck Tool Box
    If they dont have autozones way up there but try autozone.com lol
