Differential Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kris77, Jan 25, 2011.
  1. Jan 25, 2011 at 7:16 AM
    kris77
    kris77 [OP] Born in the Backwoods
    West Virginia
    08 DC TRD Sport Speedway Blue
    In channel Vent Visors, AVS Bug Shield, Hankook Dynapro RF10 265/70/17
    I know my TRD Sport has the LS diff. My question is, does the Off Road version have LS? Can you have the locker and LS? Or is it one or the other?
    I was looking at the new Fords, and the FX4 which is the off road version has the locker but no LS. Just wondering if this was the case on our Tacoma's as well.
  2. Jan 25, 2011 at 7:26 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Same thing almost. Since newer trucks use Auto-LSD (fake limited slipp) so Offroad version in theory would have AUto-LSD and Locker.:p
  3. Jan 25, 2011 at 7:40 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Nothing fake about TRAC or AUTO LSD... they slow down a spinning tire just the same.
    The advantage is you get fresh pads with every brake job... If a limited slip differential clutches wear out... $$$
  4. Jan 25, 2011 at 7:49 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The 2005-2008 TRD offroad trucks have the locker. They DO NOT have the (mechanical) LSD.
    The 2005-2008 TRD Sport trucks have the (mechanical) LSD.
    The 2009+ trucks all have the AUTO LSD.
    As an OPTION - I think you could get all the electronic stuff (VSC, ATRAC) on the earlier trucks. I'm not sure if those OPTIONED trucks had the Auto LSD instead of the mechanical (with the ATRC/VSC). I remember telling the dealer (when I purchased my truck) that I didn't want all that electronic stuff.
  5. Jan 25, 2011 at 8:08 AM
    BlueT
    NorthEast
    If they wear out, ....
    However, you can also simulate constant slip for 40 miles, just put your handbrake on for 40 miles and see how that works out for you. Do that every day for a week. :D
