Differential Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Gavingamer901, Mar 5, 2020.
  1. Mar 5, 2020 at 1:17 PM
    Gavingamer901
    Gavingamer901 [OP] Well-Known Member
    Gavin
    Grand Rapids
    02 Double Cab TRD PreRunner V6
    4X4 conversion, 2" Lift, 1-Piece Aluminum Driveshaft, 265/75/r16 Tires
    20200305_161453.jpg 20200305_161509.jpg 20200305_161453.jpg 20200305_161509.jpg 20200305_161453.jpg 20200305_161509.jpg 20200305_161519.jpg 20200305_161531.jpg
    Just realized I can see myself in these but oh well! My phones dying so I'm posting them anyways!
  2. Mar 5, 2020 at 1:17 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Oh wait... mine posted first... YOU owe me a Coke.
    Kwikvette likes this.
  3. Mar 5, 2020 at 1:19 PM
    eon_blue
    Azusa, CA
    yep that's not a TRD, someone just put those TRD decals on the back.
  4. Mar 5, 2020 at 1:19 PM
    eon_blue
    Azusa, CA
    :burp:
  5. Mar 5, 2020 at 1:20 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    You've got white guages... as far as I know, the only way you get that in 02 is with the TRD package.
    I've never heard of the TRD package with no locker... but you don't have the button.
    Toyota has always done wierd shit with options though.
  6. Mar 5, 2020 at 1:20 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Correct not a TRD, plus the white gauges became standard after a certain year regardless of the TRD package....2001?
    El Taco Diablo and eon_blue like this.
  7. Mar 5, 2020 at 1:21 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'm assuming 2001 is the change since that's when they got a face lift. Would make sense; that and I've seen 2001 models on CL with white gauges but no signs pointing to TRD.
  8. Mar 5, 2020 at 1:22 PM
    Tonkatacoman98
    Tonkatacoman98 Member
    Ray
    1999 tan Tacoma sr5 5speed manual 4wd
    Stock af
    All my apologies, thank you for setting me straight on the topic, I'd have gone on like an idiot forever making that assumption
  9. Mar 5, 2020 at 1:23 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Ok... I guess that makes sense.
  10. Mar 5, 2020 at 1:24 PM
    Gavingamer901
    Gavin
    Grand Rapids
    Alrighty thanks guys, I'll check the vin but it seems right now like it's some guys just liked the decal and stickered it on there
    El Taco Diablo likes this.
  11. Mar 5, 2020 at 1:24 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    No worries brotha... the reason we're here is to talk about Tacomas... might as well be your Tacoma lol
    Gavingamer901[OP] and Kwikvette like this.
  12. Mar 5, 2020 at 1:25 PM
    Tonkatacoman98
    Ray
    Stock af
    Someone help me again I'd always assumed the SR5 all had the little half cab mine does, I seem to be far dumber than I look (and if I do say so myself that's already pretty dumb)
  13. Mar 5, 2020 at 1:27 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    You can also do a VIN lookup and see what the tuck was supplied with from the factory, and dealer options.
    https://www.toyota.com/owners/my-vehicle/vehicle-specification
    But more than likely that's not a "true" TRD since you don't have the locker button on the dash. Other tell tale sign is looking at the differential itself. The electric locker ("e-locker") is a little box on the side of the center section of the axle housing.
    The SR5 and the TRD packages are more or less independent. You can have one without the other, although I can't recall ever seeing a TRD and wasn't an SR5 as well.
    SR5 package is just things like power windows, A/C, that sort of stuff.
    TRD package is upgraded shocks and the rear diff locker.
    Gavingamer901[OP] likes this.
  14. Mar 5, 2020 at 1:28 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I stand corrected slightly...
    Looking on craigslist, it must be a cab type when the switch happens....
    2001 Regular cab non trd prerunner has a black gauge layout
    2001 Extended cab non trd has a white gauge layout
  15. Mar 5, 2020 at 1:28 PM
    #35
    jbrandt
    Justin
    SR5 is just the name of the convenience package. Power door locks/windows, that sort of thing. It's not even a unique package to Tacomas. ALL Toyotas have an SR5 option package.
  16. Mar 5, 2020 at 1:29 PM
    #36
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    No, SR5 is a package
    Like I said... Toyota does some wierd shit with options.
  17. Mar 5, 2020 at 1:30 PM
    #37
    Gavingamer901
    Gavin
    Grand Rapids
    Okay guys so all that comes up on vin checkers are "deluxe" or "limited" so I'm guessing if it was really TRD It would say "TRD xxxxxx" on it right for the trim ?
  18. Mar 5, 2020 at 1:30 PM
    #38
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    And I don't think anyone actually has a 100% idea of what the SR5 package ACTUALLY includes... it seems to change between years and models etc.
  19. Mar 5, 2020 at 1:31 PM
    #39
    Kwikvette
    Fresno County
    4 run, 2 don't
    We're passed the TRD part, you don't have one.
    We're simply discussing changes over the years.
  20. Mar 5, 2020 at 1:32 PM
    #40
    eon_blue
    Azusa, CA
    yeah it would specify if it was a TRD model, if it's not on there then it wasn't. The dead giveaway is that you don't have the RR Diff Lock switch to the left of the steering wheel, you just have a blank plate where it would normally go.
    Also you can tell by looking underneath at the differential, the e-locker actuator is on the outside of the differential and easy to spot.
