Differential Ratio for BFG KO2 285/70/R17?
Discussion in 'Performance and Tuning' started by mvelaz2019, Apr 30, 2023.
  1. Apr 30, 2023 at 3:45 PM
    mvelaz2019
    mvelaz2019 [OP] Member
    Marcial
    2019 Metallic Gray Tacoma SR5
    None yet.
    I recently got some KO2 285’s (70/R17) and I absolutely love them, only problem is the mpg tanked and as a college student that goes on the 10 Freeway East, I can’t have this problem for much longer or my wallet will run dry, what’s the best differential ratio to run with the tires so I can go back to 16-18mpg instead of 12?
  2. Apr 30, 2023 at 3:45 PM
    AntMan408
    AntMan408 Well-Known Member
    Bay Area, CA
    2021 Toyota 4Runner off-road, 2022 Tacoma Offroad
    4runner: King Shocks Front/Rear SPC UCA’s SPC rear control arms Icon Rear Springs 52700 Icon Panhard Bar SCS 10’s RCI Skids and Sliders CBI Baja Bumper w/Diode dynamic lightbar RCI Roof Rack Tacoma: King Shocks Front/Rear Camburg UCA’s Deaver Expedition Stage 1 Leaf Pack SCS Gen 5 RCI Skids RCI Sliders BAMF Hybrid Bumper RCI Roof Rack
    Stock tire size.
    edit: lawlz thought you asked what tire size to go back to.
    BC Hunter likes this.
  3. Apr 30, 2023 at 4:18 PM
    808stateofmind
    808stateofmind Well-Known Member
    Kona
    '22 Lunar Rock TRD OR 4x4 DCSB 6MT
    Eibach pro truck 2.0/2R lift kit 1.5" AAL OME/ARB UCA BFG KO2, 285/70-17 SCS Blaze 10, 17-8.5, -10 offset ECGS bushing needle bearing replacement Clutch accumulator disk delete Poor mans TRD intake, K&N 57 series intake tube, K&N high flow filter, TRD flow accelerator
    Im getting ready to lift my truck, and im doing a bunch of research into good all terrain tires that also aren't too heavy. My truck will be mostly highway, so I know I dont need a load range e that will add a bunch of extra weight. Some of the e range ko2's can be around 60 pounds, another popular tire, the wildpeak at3 is also around 60lbs. My stock 265 TRD OR tire and rim weigh around 61 pounds. So if you buy a tire thats 60ish pounds, and a wheel thats say 25lbs or more, youre pushing an extra 100lbs, and thats not just 100lb, thats 100lbs of rotational weight. Unfortunately adding extra weight to your truck will drop your mpgs
  4. Apr 30, 2023 at 4:21 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
  5. Apr 30, 2023 at 4:26 PM
    MGMDesertTaco
    Most do 5.29 over 4.88's and then a tune. Stock automatic tacoma is 3.9 something and 4.30 for manual transmissions.
  6. Apr 30, 2023 at 6:50 PM
    mvelaz2019
    Marcial
    None yet.
    Soooo does that mean I should switch to 4.88? Or would 4.30 do me just fine? Also maybe I wasn’t clear enough with my question, but I have the diff ratio for stock tires and I wanted to know the exact ratio necessary to run 285’s without feeling slower or wasting more gas.
  7. Apr 30, 2023 at 8:52 PM
    MGMDesertTaco
    I understood your question. Most Tacoma owners who run 285s and choose to re-gear opt for 5.29 gears and an aftermarket tune to supplement or take full advantage of that gear ratio. The tune will help with shift parameters and overall performance. That would be my recommendation.
    I can't tell you what your mpg will be with those gears and 285s, because there's too many variables (weight, driving habits, terrain, ect.)
  8. Apr 30, 2023 at 8:55 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    5.29 is the only way to go on the automatic, regardless of tire size. 4.88 sometimes can make sense on manuals but often there the 5.29s make more sense too. Toyota really gave the trucks a crappy stock ratio on the autos with 3.909.
    mvelaz2019[OP] likes this.
