Differential swap and driveshaft balancing
Discussion in '1st Gen. Tacomas (1995-2004)' started by RangeDrive, Jun 19, 2017.
  1. Jun 19, 2017 at 10:27 AM
    RangeDrive
    RangeDrive [OP] Well-Known Member
    02 V6 Double cab
    Icon front end, OME Dakar rear, ARB front bar
    I am removing my front and rear differentials and swapping them to another truck. Should I swap the driveshafts too so they front become out of balance?
  2. Jun 19, 2017 at 10:33 AM
    digitalferg
    digitalferg Well-Known Member
    Southern Utah
    2006 1G Tundra DC TRD 4x4
    You do not need to swap driveshafts if you swap diffs. Driveshaft balancing is not specifically dependent upon any other parts outside of the driveshaft assembly (nor vice versa).
  3. Jun 19, 2017 at 10:59 AM
    RangeDrive
    02 V6 Double cab
    Ok thanks!
