Differential swap
Discussion in 'Technical Chat' started by 21xdbullet, Jul 19, 2012.
  1. Jul 19, 2012 at 3:51 PM
    21xdbullet
    21xdbullet [OP] Active Member
    Seale
    99 Tacoma sr5
    6" suspension lift 3" body lift 35x15.50-15 tsl xs
    I currently have a 1999 Tacoma 3.4l 4x4 auto trans and from what ive researched it has 3.92 ring and pinion with open carrier. I want to gear it lower maybe 4.10 - 4.56. Not to low tho. Atleast were it will pull my 35 x15.50 tsl xs. Right now I have no power whatsoever which could be another problem somewhere else. I have found a matching number front and rear set but don't know if it's interchangeable. It's out of a 1990 4 runner and has the independant front diff. Will this work in my 99. Thanks guys
  2. Jul 20, 2012 at 9:36 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    No, the rears are definitely not interchangeable with those older trucks. Not sure about the fronts, but not likely. You'll have to get yours re-geared. You'll likely need 4.88 gears to pull 35's.
  3. Jul 20, 2012 at 12:09 PM
    neegdogdig
    neegdogdig Untrained with bad experiences go go go!
    3rd Gen DC V6
    do not swap unless you do some mods.
    in my own experienced any tires size 35 and above
    ill go with 5.29 gears.
  4. Jul 21, 2012 at 5:27 AM
    21xdbullet
    Seale
    99 Tacoma sr5
    What kind of highway speeds will I see with 4.88 or 5.29
  5. Jul 21, 2012 at 5:30 AM
    21xdbullet
    Seale
    99 Tacoma sr5
    I have 3.92 with open carrier will I have to change
    Carrier if I swap gears and possibly add locker
  6. Jul 23, 2012 at 4:37 PM
    tan4x4
    Rick
    Folsom, CA
    Just changing gears does not require a different carrier.
    ARB and DETROIT lockers replace the stock carrier.
    Lock-rite uses the stock carrier.
