Differential / Transaxle Service
Discussion in '2nd Gen. Tacomas (2005-2015)' started by artie707, Oct 22, 2023.
  1. Oct 22, 2023 at 3:51 PM
    artie707
    artie707 [OP] Member
    Art
    2012 Toyota Tacoma Prerunner Sport
    So I got my first oil change from the dealer since I bought my used 2012 Tacoma off-road with 158577 miles. from what the carfax states the previous owner kept up on the truck's maintenance it was his daily commuter, and now it is my 23-mile two-way commuter, the dealer recommended diff and trans service, but I'm not a fan of the dealer(2 bad experiences) because they always try to scare you with what needs to be done with your car, and I have my own mechanic, but the oil change was free. What are your thoughts (TW Family) first Taco had a Highlander before, love Toyotas
  2. Oct 22, 2023 at 3:56 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Ideally, you’d want to do the differentials every 30k.
    And transfer case ever at least every 50k. (Or sooner)
    Can you you get by going longer. Probably.
    Some people never change them. But I don’t recommend it.
  3. Oct 22, 2023 at 3:56 PM
    AwArD
    AwArD Well-Known Member
    2012 Tacoma Trail Teams TRD sport Double Cab V6 4.0
    Icon Rxt rear leaf option 2 Elka 2.5 DC Reservoir Front/Rear with 600lbs/14inch coil JBA Offroad STD high caster UCA Whiteline LCA inner bushing Mevotech TTX LCA Ball joint Woodward U-Joints Intermidate steering shaft mod Uni filter mod TRD Cat-Back Exhaust Timbren Active Off-Road Bumpstops Front/Rear Overland Torque Tune (OTT) by Yotatune Amsoil signature engine/transmission Amsoil SEVERE GEAR 80W-90 Front/rear diff and T-case Tacoma bed mat Weathertech mat front and rear cabin Summer BFG Ko2 265/65r17 E rated / Fuel Rebel 6 Bronze wheels Winter Nokian Hakkapeliitta 10 studded, 265/65r17 / oem Toyota wheels
    I follow this guide (it's everywhere on Tacomaworld). If your truck love mud and water, you will need to change the diff oil sooner i case there water contamination by the vent tube.
    Buy all the washer at the dealer. And it take 6 quarts of 80w-90 or 75w-90 (both work). It take maybe 2 hours and you will be sure that it's done correclty and you will see the condition of the oil
  4. Oct 22, 2023 at 3:59 PM
    artie707
    Art
    wow that was quick thanks alot fellows
    AwArD likes this.
