Differential & Transfer case Gear Oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gmcuajo, Feb 17, 2017.
  1. Feb 17, 2017 at 9:58 PM
    gmcuajo
    gmcuajo [OP] Well-Known Member
    Puerto Rico
    Just -sylvania ZXE on head & fog lights -the tires
    This question may be asked many times, but can I use store available gear oil for differentials and transfer case?
    I have 2013 Tacoma Double Cab Off-Road, 4x4 with the rear e-locker etc.
    45,000 miles
    Want to change the differentials (both) and transfer case oil.
    Manuals calls
    1. differentials: "Toyota synthetic 75W-85"
    2. Transfer case "75W-90"
    Both GL-5
    On stores ther is Valvoline and Mobil 1 synthetic 75W-90. It is ok to go with that, or do I have to purchase the expensive 75W-85 from Toyota (approx $25 per Qt)?
    Do I need any other additive?
  2. Feb 17, 2017 at 10:14 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    I've always used oil off the shelf at NAPA or what not. As long as it is the correct weight and type, go for it. Most oils will list what they're compatible with (GL-5, etc.)
    No LSD additive for you, as you do not have a mechanical limited slip.
  3. Feb 17, 2017 at 10:15 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Norton likes this.
  4. Feb 17, 2017 at 10:25 PM
    gmcuajo
    Puerto Rico
    Thanks!
    Also,
    1. What about replacing spark plugs every 30k miles for the 1GR-FE (tacoma V6)?
    2. Replacement of coolant? Needed at 45k miles?
    3. Brake fluid?
  5. Feb 17, 2017 at 10:30 PM
    Mxpatriot
    I did spark plugs at like 90k. I wouldn't replace coolant or brake fluid that early unless you just want to do it to do it.
    I do not do all the maintenance by the book. Sometimes i do it early, sometimes later. Kind of go by feel based on how I've used the truck and events.
    gmcuajo[OP] likes this.
  6. Feb 17, 2017 at 11:40 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    If the oil you buy or find says it has the LSD additive, don't worry as it won't hurt anything if it's in the oil even tho you don't need it.
    SandyTaco4x4 likes this.
  7. Feb 18, 2017 at 1:53 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Most guys on here have said they use 75/90 on all three and no issues. Don't get sucked in to the dealer telling you that only the Toyota brand fluid works...its BS and VERY expensive.
    Synthetic 75/90 fluids can be had for less than $15/qt at any auto parts store. Less than that for the non-synthetic obviously.
    SandyTaco4x4 and Norton like this.
  8. Feb 18, 2017 at 4:42 AM
    badger
    badger Well-Known Member
    07 SR5
    Flushing the brake system with new fluid is almost always neglected. Most corrosion related failures could be avoided by doing this. I would do it at least every 100k.
    Marc70 and Autotruckin like this.
  9. Feb 18, 2017 at 7:31 AM
    gmcuajo
    Puerto Rico
    Manual says
    Replace coolant at 100k, then every 50k. But I always change like every 3 years to my previous cars, and that is recommended by every expert. Coolant is coolant.
    The same with break fluid, always has changed like every 3 years to other cars.
    SWPA Tacoma likes this.
  10. Feb 18, 2017 at 7:32 AM
    gmcuajo
    Puerto Rico
    Yes. Will go with Valvoline or Mobil 1 synthetic.
    Toyota is ridiculous!
    lynyrd3 likes this.
  11. Feb 18, 2017 at 7:49 AM
    aggietaco
    aggietaco Well-Known Member
    Texas
    2021 2500hd custom
    I thought the LSD additive was only for pre-2009 sport models as well?
    Marc70 likes this.
  12. Feb 18, 2017 at 7:56 AM
    Large
    Large Red
    I would do the plugs, it's a 20 minute job and costs next to nothing. Coolant is 100k miles, brake fluid is when it gets dark imo.
    I also do the throttle body and the MAF sensor every 15k and both diffs / tcase every 30k with 85-140.
  13. Feb 18, 2017 at 8:48 AM
    gmcuajo
    Puerto Rico
    Why 85W-140? Isn't too thick?
    What about the tb and maf, clean with throttle cleaner?
  14. Feb 18, 2017 at 9:27 AM
    Large
    Large Red
    ECGS recommended 85-140 with the nitro gears, been using it without issues for over 50k miles. And there is special MAF cleaner and TB cleaner you can get from autozone, I bought a cab of each years ago and it's still got some left in it. Use it outdoors or with a mask.
    lynyrd3 likes this.
  15. Feb 18, 2017 at 9:32 AM
    Pigpen
    Dan
    Northwest Montana
    Brake fluid takes on water faster in cold climates, so I flush mine every 2 - 3 years. Down in PR, I'd imagine you could stretc
    Holy shit. I can barely get the passenger side plugs changed in 20 minutes, let alone the driver side.
  16. Feb 18, 2017 at 11:26 AM
    Large
    Large Red
    It helps that my intake is disconnected from the manifold
  17. Feb 18, 2017 at 3:35 PM
    jmich2001
    jmich2001 Well-Known Member
    Toms River, NJ
    12 Access Cab TRD OR
    Yellow Fog Lamps, Ham Radio
    I did my plugs at 30K, piece of cake.($15 for densos)
    I did a drain and fill at 30K on my coolant (toyo pink pre-diluted($19)
    I had the dealership flush brake fluid at 40K.($120)
    I also had dealership drain/fill auto trans at 30K ($190)
    lynyrd3 likes this.
  18. Feb 18, 2017 at 3:56 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    If your truck is still under warranty I would stick with 75w-85 and you can get it in Red Line for a lot less than the Toyota brand. The manual calls for plugs every 30k so I would stick with that recommendation also.
  19. Feb 18, 2017 at 6:33 PM
    flying_az
    flying_az Well-Known Member
    Scottsdale, AZ
    2014 TRD Off Road, 4X4, MT
    Old Man EMU, Avid sliders, Pelfreybilt skids, winch mount bumper & winch, 265/75-16 BFG KO2s, fiberglass tonneau cover, flexible mud flaps, locking tailgate, debadged, decals removed, breather relocate
    I did my first 30k spark plug change last week. My gas mileage increased by 1.5 mpg, so I'd say go ahead and do it.
  20. Feb 21, 2017 at 10:19 AM
    tgear.shead
    tgear.shead Well-Known Member
    The transfer case needs MANUAL TRANSMISSION FLUID that is compatible with BRASS SYNCHRONIZERS.
    I would avoid the mobile 1 for the transfer case, they are *really terrible* for synchronized gear sets, despite the claims on the bottle. I had that crap in my transmission for roughly 2000 km, and it really made shifting difficult when cold. The transfer case has one synchronizer, which is for engaging the front drive. While it is electronically operated and you can't feel it, I'd be concerned about stressing it out over time.
    Can't speak to the valvoline stuff, never tried it.
    Amsoil MT fluid is good in the transfer case and manual transmission.
    The mobile 1 will be fine in differentials.
