Differential
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmettx, Aug 16, 2016.
  1. Aug 16, 2016 at 7:58 AM
    jmettx
    jmettx [OP] Active Member
    2005 TRD V6
    2005 Tacoma, V6, TRD, 4WD, manual trans.
    Any suggestions for front and rear differential fluid brands/types? I normally would not ask such a stupid question, but I learned my lesson when I used less expensive fluid in my manual trans.
    Also, any tips or things to be aware of when changing these fluids. I heard that doing the front differential can be a pain in the butt for some reason.
    Thanks.
  2. Aug 16, 2016 at 8:05 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    85w140 Lucas Non-Synthetic for me. You don't have to worry about LSD additive with this as well if you have the mechanical LSD in the rear. The front is a PITA because you need a pump to get the fill the fluid back up. Not to mention the smell of diff fluid.
    Darth_Yota likes this.
  3. Aug 16, 2016 at 8:13 AM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    Red line 75w-85 in your diffs and transfer case (or 75w-90 if you tow a lot or run in hot weather a lot). Redline MT-90 in your tranny.
    Biggest tip is to loosen the fill plug before you dump the oil. Also doesn't hurt to hit all the plugs with PBblaster or WD-40 the night before you do the deed.
  4. Aug 18, 2016 at 10:54 AM
    jmettx
    2005 TRD V6
    @zippsub9 @timothom Thanks for the input. Do either of you know the proper torque for the fill/drain plugs on the rear and front differential?
  5. Aug 18, 2016 at 10:57 AM
    TacomaArto
    TacomaArto Well-Known Member
    Wisconsin
    2015 White DCSB SR5
  6. Aug 18, 2016 at 11:01 AM
    timothom
    Also be sure to buy some new gaskets/washers for all the drain and fill plugs. It's cheap insurance for 15 bucks.
    Lester Lugnut and Norton like this.
  7. Aug 18, 2016 at 11:09 AM
    timothom
    The Redline MT-90 in my tranny made a noticeable difference in feel when I'm downshifting into 2nd and 1st. I'm very glad I did it at 20k.
    Also, since you have 4wd, you have greese points on your train. I think there's 2 on the front driveline, and 3 on the rear one.
  8. Aug 20, 2016 at 7:37 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    +1.
    FWIW, I run Amsoil Severe Gear 75W-90 in the transmission, transfer case, and both diffs.
  9. Aug 20, 2016 at 8:27 AM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    I will echo the Redline synthetic- I have used it in multiple applications- great in a manual transmission!
  10. Aug 20, 2016 at 1:48 PM
    locster
    locster Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    I though that stuff is only for the differentials. Why are you running it in your transmission?
  11. Aug 20, 2016 at 3:42 PM
    Norton
    I don't know how to ask without sounding sarcastic, but that's not my intent... Is this a trick question?
    I run it there because it meets/exceeds transmission lubrication requirements and the truck seems to shift more smoothly with it than the OEM lube.
  12. Aug 20, 2016 at 5:01 PM
    timothom
    Trans is spaced for gl3, which is supposedly a bit easier on the syncros. I don't think it makes much difference personally. Things and old posts on this forum make a big deal about this. Amsoil is a top quality product and I fully expect @Norton transmission to last as long as mine:)
  13. Aug 20, 2016 at 9:18 PM
    locster
    Luke
    Orange County, CA
    2014 DCSB 4x4
    Sorry, I should have been more clear. I thought Amsoil makes a separate product line for the transmission, and the Severe Gear line is just for the differentials.
  14. Aug 20, 2016 at 10:24 PM
    Norton
    GL-4 and GL-5 are American Petroleum Institute (API) service characteristic ratings for (spiral-bevel and) hypoid gear lubricants. The primary difference between GL-4 and GL-5 is the amount of extreme pressure additive package. (GL-4 has less than GL-5 does.) The caution here tends to be with regard to certain manual transmissions. The GL-4 specification is primarily used for those with high yellow metal content (e.g., brass and/or bronze sometimes found in manual transmission syncros). Under certain conditions, the higher additive content can corrode yellow metals. According to the folks at Amsoil, Severe Gear® 75W-90 is "recommended for use in differentials, manual transmissions and other gear applications requiring any of the following specifications: API GL-5... Can also be used in axles where an API GL-4 lubricant is recommended."
    According to p.460 of the Owner's Manual, the manual transmission calls for "API GL-4 or GL-5" 75W-90.
    Got it. Thanks for the clarification!
    You're correct, in that Amsoil does offer several suitable products including Manual Transmission & Transaxle Gear Lube 75W-90, 75W-90 Long Life Synthetic Gear Lube, and Severe Gear® 75W-90. I went with the latter to keep things simple, since it's also recommended for both differentials and the transfer case. As mentioned above, Severe Gear® 75W-90 is safe for both API GL-5 and GL-4 applications.
  15. Sep 21, 2016 at 9:28 AM
    jmettx
    2005 TRD V6
    @zippsub9 @timothom @Norton @TacomaArto
    Sorry, here is my dumb question of the day. If my 2005 Taco TRD six speed has a rear locking differential button on the dash, that means that it does NOT have a limited slip differential, correct?
    I need to buy the fluid today and want to make sure I get the right stuff. Thanks.
  16. Sep 21, 2016 at 9:35 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    You shouldn't need the LSD additive. As I understand it, you have an open differential with an electronic locker mechanism.
    Prior to 2009 there were mechanically locking LSDs that could be purchased stock on the Tacomas. If you have a factory e-locker (which explains the switch) then you don't need the LSD additive to your fluid. If this were a post 2009 auto or electric LSD controlled by the brakes and not clutches in the third member, then you not need the additive as well.
    Norton likes this.
  17. Sep 21, 2016 at 11:49 AM
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    My 05 has also locking in4 wheel low only.witch only locks axle one to one no clutches or other friction engagement.on Tacoma world you can modify it to lock up whenever( stopped!).look it up.No posi in the carrier.I use Mobil 1 Syn.Or whatever.read on my friend.
  18. Sep 21, 2016 at 8:36 PM
    Norton
    Correct. As @zippsub9 said, you have an open differential with an electronic locker mechanism.
    Our TRD OR trucks do not require LSD additive. (The same was true of my 1st Gen TRD OR.)
