Differentials and transfer case gaskets
Discussion in '2nd Gen. Tacomas (2005-2015)' started by REAL_OG, Jan 21, 2023.
  1. Jan 21, 2023 at 12:19 PM
    REAL_OG
    REAL_OG [OP] Well-Known Member
    All, in my opinion I only believe the crush gaskets in rear differential drain/fill and front differential fill crush gasket should be replaced.
    the front differential drain copper looking gasket is more of a washer since it’s pretty thick and shows no signs of deformation.
    I don’t believe it needs to be replaced
    the same goes for the two transfer case gaskets, they are both pretty thick and would almost see these as washers more than gaskets since they also show no signs of deformation. They are also pretty thick
    just an observation what does everyone think after replacing them all twice already ??
    I may only stick to just replacing the crush gaskets
  2. Jan 21, 2023 at 1:54 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I replaced mine. But only because I had new ones.
    I’d be ok with reusing them.
    I’ve reused the smaller crush ones many times.
  3. Jan 21, 2023 at 4:16 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    If you are in a pinch and don't have a new one it won't hurt to re-use it versus nothing at all.
    If you aren't in a pinch and can plan ahead to buy new ones they cost like a dollar. Silly not to do it.
    Pinching pennies on something so cheap is an idiotic way to maintain a truck.
  4. Jan 21, 2023 at 4:28 PM
    REAL_OG
    I spent a little over 30 bucks for a full oem set. Let me know where you find them for a dollar a piece.
    If you read carefully some are almost questionable to be gaskets and more like washers since they are solid/thick as hell
  5. Jan 21, 2023 at 4:33 PM
    DJSpeed
    DJSpeed Well-Known Member
    https://www.amazon.com/gp/product/B0B2PFK5WJ?smid=A27HIFQANKXUBL
    bought these for years. and side by side with the ones from toyota. they were identical. 6.99 for 18 pieces. so roughly 40 cents a piece
    TnShooter likes this.
  6. Jan 21, 2023 at 4:40 PM
    wi_taco
    Adam
    SE Wisconsin
    Lewis Toyota of Topeka online parts store. I just ordered as recently as January 2nd so like 3 weeks ago. Here were the prices:
    12157-10010 = $1.23 each
    90430-24003 = $1.55 each
    90430-18008 = $1.41 each
    Buy a couple at a time, add them to an order for other maintenance things like air/cabin filters, oil fiters, etc. Get the free shipping. Again, it's silly to pinch pennies on this kind of stuff when everything else costs more.
    Or buy this, it's pretty hard to screw up a metal gasket so aftermarket Amazon stuff should work fine. I personally don't buy stuff at Amazon but that's me, and I don't criticize if you do. I've eaten hamburgers that cost more than this gasket kit. Again, silly to skip it.
