Difficult to replace clear plastic gauge covers?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DavisBladeWorks, Sep 29, 2013.
  1. Sep 29, 2013 at 4:05 PM
    DavisBladeWorks
    DavisBladeWorks [OP] Well-Known Member
    North ATL
    2013 DSCB TRD Sport 4x4
    Hey guys, in my brand new truck the gauge faces look terrible, and I mean worse than any new vehicle I've ever had. They are swirled like crazy, like whoever cleaned them off at the factory didn't clean off the hard particulate before wiping them down.
    Anyway, this has always been a pet peeve of mine in every vehicle, but this one is just too much since I look in that area all the time. Not to mention if the sun hits them directly you cannot even see the speedo.
    All that to ask, are the clear plastic pieces easy to replace? I guess better than asking is it easy, I should ask if it's even possible to do without pulling out the whole dash. I'd really like to replace them myself, since I could take care not to scratch them and also add a protective layer before I install. Thanks guys!
  2. Sep 29, 2013 at 5:49 PM
    DavisBladeWorks
    North ATL
    Guess no one has replaced theirs?
  3. Sep 29, 2013 at 5:57 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    If they're crap from factory take it to the dealer. They'll talk to toyota, if they're that bad and will likely be replaced under warranty.
  4. Sep 29, 2013 at 6:06 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Whole cluster I imagine.
  5. Sep 29, 2013 at 6:15 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
  6. Sep 29, 2013 at 6:15 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    I have seen people talk about just replacing the plastic piece alone.
  7. Sep 29, 2013 at 6:16 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
  8. Sep 29, 2013 at 6:17 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
  9. Sep 29, 2013 at 6:25 PM
    Tacorriendo
    Tacorriendo Well-Known Member
    Fred
    Texas
    2009 DCSB 4x4 Off-Road
    Front lift, ride rite air bags, side steps, rear camera switch.
    I had the same issue with my 2009 when I bought it out of state, so I did not know until it was delivered on my driveway. It look like some one use a harsh chemical to clean it and burned the plastic, so it looked all blurry. As soon as I got a chance, I removed the cluster and used the same polish and tool they use for the headlight lens and went medievel on them. Now they look clear as crystal. Like if there is no plastic at all. I was a happy camper again. The End.
  10. Sep 29, 2013 at 7:27 PM
    NorCalTRD
    NorCalTRD Well-Known Member
    Northern California
    '06 Indigo Ink DCLB TRD Sport V6
    40% Front Tint, Viper 5704 Alarm, Steel Cable Dog Tie, Super Sexy Driver Mod
    ITS SUPER EASY!
    Just get the clear plastic housing for like $18, open up your dash and swap it out.
    20 minute job max.
  11. Sep 29, 2013 at 7:30 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Remove the plastic and replace with saran wrap, cheap and easy.
  12. Sep 29, 2013 at 7:33 PM
    DavisBladeWorks
    North ATL
    Awesome to hear. Is there a pictorial anywhere that shows how? Thanks!
  13. Sep 29, 2013 at 7:34 PM
    fenderpicks
    fenderpicks Well-Known Member
    I thought i was the only anal one about the gauge clear plastic.
    I was cleaning, i wiped it with a HIGH QUALITY Microfiber towel, and it still scratched the plastic, it is TRASH seriously.... but i am too lazy to pull the thing to replace that plastic lol
  14. Sep 29, 2013 at 7:44 PM
    DirtJumper14
    DirtJumper14 Well-Known Member
    SoCal
    2005 TRD OR
    5100's, BDF grills and light bracket, big 3 upgrade, ATH bed braces, snugtop xtra vision shell, (bed, shell, hood, rock, front, rear, footwell, glove box, center console led lighting), MESO Gasshole, MESO dome and map lights, Flyeyez center console light, custom fuse panel, TRD CAI, toyota bed mat, 2013 black carpet, 2015 side mirrors, BedRug, AJT key fob, ultraguage, 8 cadillac horns acdf, pop n lock tailgate lock, energy suspension bushings, spicer greasable ujoints, Rigid lights everywhere, kenwood stereo, led tube taillights (red), 2018 T4R trail wheels, rokblok mud flaps, TRD skid plate, RCi gas tank skid plate
    It's really easy. Just remove the lower dash under the steering wheel first (of course after you unclip the door threshold and kick panel and the pocket section to the right of the steering wheel). The piece that surrounds the gauges and has the fog light switches is just held on by a few clips and 2 screws above the gauges. Just pull gently then remove the plugs for the dimmer and whatever other plugs are back there depending on your options and that will expose the cluster. The clear cover is held on by about 6-8 clips that you will see. Comes right out. Just took mine out to clean some dust and crap.
  15. Jun 17, 2015 at 6:59 AM
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    I have the exact same issue on a 2013. Some dickhead at the dealer must have used a harsh chemical and the whole thing is hazed and scratched like a 20 year old car. My 11 year old Subaru is in far better shape!
    Thanks for the heads-up on the part number. I'm going to be doing this right away. Nothing more irritating than looking down in the sun and seeing nothing but haze when you try and see how much gas you have left.
  16. Nov 20, 2020 at 12:04 AM
    stvhwrd
    stvhwrd Well-Known Member
    PNW
    2014 Black Tacoma 4x4 DCSB
    2.5” OME lift, TRD Pro wheels, 34x10.5 BFG KO2s, Garmin dash cam, temp/compass rearview mirror, Alpine ILX-W650 + Infinity reference components, rear diff snorkel, heated seats
  17. Nov 20, 2020 at 1:13 PM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    I replaced mine twice already. Once when i got it used. It was cloudy and then the dealership detailers fucked it up.
    Now I don’t let anyone wash it.
    The way i clean it now i start with compressed air blow off the dust then use plexus and saturated the lense and wipe gently clean
    stvhwrd likes this.
  18. Nov 20, 2020 at 1:25 PM
    stvhwrd
    PNW
    I think that's exactly the right way to do it, and that's what I intend to do too. I had never heard of Plexus before this thread but reading more about it, it sounds like a great product. I'm seeing it used for motorcycle helmet visors, motorcycle windshields, etc.
    Do you have any other nifty uses for it?
  19. Nov 20, 2020 at 1:31 PM
    TACOMA2NDGEN
    ROLAND
    new jersey
    baja squadron pros
    I use it on my headlights and taillights also. I was introduced to it about 10 years ago when i had my jeep with a soft top it was excellent for cleaning those windows
    stvhwrd likes this.
