Difficulty Changing Battery.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikeDeason, Feb 20, 2023.
  1. Feb 20, 2023 at 7:44 AM
    MikeDeason
    MikeDeason [OP] Well-Known Member
    I know I’m going to get riled but I’ve owned Gen 2 for 14yrs and always had batt changed “free” with purchase
    can save about $20 if I buy at Wal Mart and do myself. Is this just a simple few bolts or is their anything nefarious awaiting
    HondaGM likes this.
  2. Feb 20, 2023 at 7:48 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Its easy, two terminal bolts and two hold down nuts with one bracket.
    HondaGM likes this.
  3. Feb 20, 2023 at 7:49 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Have you never opened the hood of the truck?
    The job takes ten minutes from the time you pop the hood until you shut the hood, requires basic hand tools and is super simple. Two nuts on the hold down bracket and two nuts on the terminals.
    HondaGM and wilcam47 like this.
  4. Feb 20, 2023 at 7:51 AM
    MikeDeason
    Yea. It looks easy but I had an 02 F150 that looked easy. It ended up taking me an hr because of a bracket snapping
    HondaGM likes this.
  5. Feb 20, 2023 at 7:57 AM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    I had to change the battery on my parent’s Plymouth Breeze once, what a pain. Have to remove the wheel, wheel well liner and a bunch of shit to get to it.
  6. Feb 20, 2023 at 9:27 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    :confused:
    wilcam47 and HondaGM like this.
  7. Feb 20, 2023 at 9:31 AM
    scocar
    scocar Patron of the Farts
    You can watch a you tube video and certify yourself in 2.5 minutes.
    But if you have a 2002 Jetta with a bad battery, just launch the car off a cliff. Fuck those things.
  8. Feb 20, 2023 at 9:31 AM
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    It's pretty straight forward. No surprises.
  9. Feb 20, 2023 at 9:31 AM
    scocar
    omg you need help with this too?
    HondaGM likes this.
  10. Feb 20, 2023 at 9:33 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Easy. Pull the positive cable off first, set aside. Then the tie down bracket, then negative last. Pull the old battery out, put new battery in. Connect.
    Don't use a wrench that's long enough to touch both terminals simultaneously.
    That's pretty much all I have to say about that. :cookiemonster:
  11. Feb 20, 2023 at 9:49 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  12. Feb 20, 2023 at 10:55 AM
    shmn
    shmn Well-Known Member
    Pacific NW
    2007 Tacoma 2.7L 5sp
    Generally, it's better to remove negative cable first that way the all grounds (other than battery post) are removed and the chances of causing a short while removing the positive cable are diminished. If you remove positive first and your wrench touches a bracket or body or any grounded metal...you will cause a serious short circuit, sparks and "rookie marks" on your wrench.
    https://mechanicbase.com/electric/which-battery-cable-to-remove-first/
    HondaGM and davidstacoma like this.
  13. Feb 20, 2023 at 2:05 PM
    MikeDeason
    Ive always removed negative first and do reverse on the install. Im in landscape maint and do lots of batts on z's.
    One thing Ive learned is that sometimes even the simplest job can have a surprise that turns it into a nightmare.
    Case in point. The primer bulbs on some of my 2 stroke units. Some are 3 min jobs and some you got to take apart the whole freaking guts and its a good hr. Or a hydro oil/filter change. Some are 15 min, some can be a 1/2 day affair.
    You never know what lurks until you do it or ask.
    HondaGM likes this.
  14. Feb 20, 2023 at 2:20 PM
    Waasheem
    Waasheem
    2007 xrunner
    Chill. We all learned how at some point.
    Put a rag over the positive, disconnect the negative then the positive, remove the J bolt nuts, out with the old, in with the new. Get the J bolts and bracket on finger tight. Use a battery brush on the terminals and posts, positive on, cover with a rag again, negative on. I like corrosion prevention felt pads to go on under the terminals. Tighten J bolt nuts.
    If the terminals were covered with acid. After taking the old battery out, put a little coke cola in a small cup, set the cup or cups where the battery goes, dunk the terminals, leave it. Come back later they'll be sparkling clean. You might have to scrape and resoak. I haven't seen anything work better to clean than coke.
    https://www.amazon.com/gp/product/B001DKUTR0?ie=UTF8
    HondaGM likes this.
  15. Feb 20, 2023 at 2:34 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
  16. Feb 20, 2023 at 3:58 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The worst part is sitting the battery down in the truck. My battery had no carry strap. So it was all “finger tips”.
    Finger cramps:rofl:
    HondaGM and b_r_o like this.
  17. Feb 20, 2023 at 4:02 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    TnShooter[QUOTED] and HondaGM like this.
  18. Feb 20, 2023 at 4:10 PM
    Waasheem
    Waasheem
    2007 xrunner
    This is the 3rd one I've tried, and the best of them. The other 2 would occasionally drop it if bumped just right. I haven't dropped one with the new one.
    https://www.amazon.com/gp/product/B0002SRD0U?ie=UTF8
    My super battery brushes. I use my old Milwaukee impact driver set for drill. The Dewalt doesn't have drill feature and messes them up.
    https://www.amazon.com/gp/product/B07FJN51J9?ie=UTF8
    https://www.amazon.com/gp/product/B00I3GNM62?ie=UTF8
  19. Feb 20, 2023 at 4:42 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Put a little oil on that hold down stud first. I did my last one in the parking lot at Autozone. The one before that, I did in the parking lot at Wal Mart. I know.... yes, I was that guy but came out from WM and the truck wouldn't even crank over.
    jackn7 and HondaGM like this.
  20. Feb 20, 2023 at 4:54 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The rear J-hook is riveted to the battery tie-down bar, so you have only the front J-hook to loosen. A 10mm deep socket takes care of it. This does mean the replacement battery needs to be the same height. Group 35, group 24F, and group 27F should all work.
    After you replace the battery, the engine will die on the first start. Known ECU logic.
    HondaGM likes this.
