Difficulty of installation for U-Bolt flip kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Southwest Tacoma, Feb 28, 2024.
  1. Feb 28, 2024 at 1:24 PM
    Southwest Tacoma
    Southwest Tacoma [OP] Well-Known Member
    Southwest
    2020 Super White SR DCSB
    I'm looking to purchase the Archive Garage u bolt flip kit for my Tacoma. I would order option 3 with the bump stops.
    Does this require removing the leaf springs to install? Or, is it just removing the bolts and stock bumps to install new parts?
    71tattooguy likes this.
  2. Feb 28, 2024 at 1:51 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Remove bolts etc.. install new parts all good :thumbsup:
    drizzoh and BabyBilly like this.
  3. Feb 28, 2024 at 2:06 PM
    tacotroy17
    tacotroy17 Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
    You could swap them without even using a jack.
    drizzoh and wilcam47 like this.
  4. Feb 28, 2024 at 3:15 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Easy as long as you have a decent selection of tools (wrenches and sockets) and a torque wrench. As others have said, just leave the truck on LEVEL ground and do one side at a time.
    Edit: depending on the kit, you may need to trim the U-bolts with an angle grinder after the install...
    https://youtu.be/PBiqCK-6fQo?si=Nprs0atdFfxNkKJR
    71tattooguy and MGMDesertTaco like this.
  5. Feb 28, 2024 at 3:30 PM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    no, just block the truck well, put the axle on a jack stand so you can get your head in the space you need to work better because removing the tire gives a ton of room. but not directly under the mounting plate! remove the 4 bolts... or if your truck is super rusty, cut with an angle grinder. if you have a block in the way make sure the U-Bolts are long enough to snug down, and get then bolts as even as possible.
    okay after seeing this kit, don't put the bumps on the truck mounts until the last end! if they are like my Timbren flip kit. was way easier to get the bolts snugged up with the bump stop not in the way and then the bump install was super easy.
  6. Feb 28, 2024 at 3:53 PM
    Southwest Tacoma
    Southwest
  7. Feb 28, 2024 at 3:55 PM
    Southwest Tacoma
    Southwest
    Thanks for the responses. I assumed it was pretty straight forward. I do all my truck work in my garage. Flat surface, wheel chocks, and all the necessary tools.
  8. Feb 28, 2024 at 3:57 PM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Kumho AT52 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 replacement head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    Is the reason you do this mod is to get more off-road clearance in the rear end nearest the tires. Is the overall new clearance higher than bottom of rear differential case? I don’t go off road except when hunting. Just curious.
  9. Feb 28, 2024 at 4:01 PM
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    Yes. Removes stuff that can snag rocks. Also, a lot of the bump stop upgrades require a flip kit.
