Difficulty starting / excessive cranking any ideas?????
Discussion in 'Technical Chat' started by cl2202, Jul 25, 2011.
  1. Jul 25, 2011 at 4:37 PM
    cl2202
    cl2202 [OP] Member
    Wichita, KS
    2008 TRD Off Road 4x4
    3" Pro Comp suspension lift.
    Hey all,
    New to the forum and a first time Toyota owner. Looking for some advice for my 2008 Tacoma double cab TRD off road. When I turn the key the engine will crank at least 5-10 seconds before starting. The truck has 117k and came from the southwest. Pretty dusty everwhere. The air filter is clean but I left the air filter box unsnapped (with a gap - several inches )for air and tried to start it. It seemed to start fine time after time. Could it be the inner or secondary filter is clogged or possible some sensor is going bad? Any ideas would be appreciated.
    Thanks
  2. Jul 25, 2011 at 4:41 PM
    Sheppymach
    Sheppymach Well-Known Member
    Sheppy
    Philadelphia, Pa
    2014 4Runner trail edition
    BLU LOGIC bt, avid, weather tech mats & rain guards, 285/70/17, BenWA's totally AWESOME power sliding window mod.
    timing, timing belt issue?
  3. Jul 25, 2011 at 6:43 PM
    cl2202
    cl2202 [OP] Member
    Wichita, KS
    Thanks. Hope it isn't the timing chain!
  4. Jul 25, 2011 at 7:53 PM
    cl2202
    cl2202 [OP] Member
    Wichita, KS
    Any other ideas???
    Thanks
  5. Jul 25, 2011 at 7:59 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    wasn't there a tsb on this? maybe try unplugging your battery for a little bit and then trying. resetting the ecu i think solved excessive cranking on someones tacoma in a thread awhile back that i saw. maybe maybe not..
  6. Jul 25, 2011 at 8:11 PM
    cl2202
    cl2202 [OP] Member
    Wichita, KS
    Thanks. I'll give it a try.
  7. Jul 25, 2011 at 8:26 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Had the same issue with my truck when new. Look at TSB EG011-07...intermittent no start condition. They do a re-flash of the ECU to fix it.
  8. Jul 25, 2011 at 8:27 PM
    ds46000
    ds46000 Well-Known Member
    07 PreRunner TRD Sport
    yeah, several threads on this...and i've responded to a few of them myself. do a search for hard start or something to that effect. there is a tsb for this, they reflash the computer. even if your truck is not under the 3 yr/36kmile warranty, it's still covered due to some sort of emissions warranty. just search for hard start tsb, or hard start, hard to start, won't crank, etc....you'll find it. good luck.
    i see offroad toy gave you the tsb # while i was typing...so there ya go!
  9. Sep 15, 2011 at 11:14 AM
    cl2202
    cl2202 [OP] Member
    Wichita, KS
    FINALLY FIXED. I took my truck to the local Toyota dealer. First they said it was my fuel pressure regulator. They also said I needed to change the plugs but that wasn' the problem. I did the plugs and saved myself over $150. They replaced the fuel pressure regulator and I still had the same problem. (Excessive cranking on cold starts.) Then they said it was my fuel pump and replaced it. NOPE! still not fixed. After dropping a significant amount of money for them to replace un-needed parts without fixing the problem I had a conversation with the manager. I was assured they would fix the truck and "make it right". After a week they called and said the injectors were leaking. They replaced all the injectors and did "make it right", not charging for the injectors and labor. It starts great now and I have pretty much a new fuel system.:)
