difrential lock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jasona250, Jun 14, 2010.
  1. Jun 14, 2010 at 7:25 PM
    jasona250
    jasona250 [OP] Well-Known Member
    jason
    ventura california
    07 double cab prerunner trd offroad
    in what situations would you use your difrential sysytem
  2. Jun 14, 2010 at 7:35 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    only when you are extreamly stuck
  3. Jun 14, 2010 at 7:40 PM
    jasona250
    jason
    ventura california
    okay thanks i have a 2wd and wasent really sure when i should use it
  4. Jun 14, 2010 at 7:44 PM
    blt4bja
    blt4bja Member
    So cal
    05 trd
    BEFORE your extremely stuck!!!
    and on the street all it will do is wear out tires and make your truck push a bit when turning. lots of fun when its wet out:):):)
  5. Jun 14, 2010 at 7:47 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    use it before you are stuck to prevent getting in that situation ;)
    off road use only
  6. Jun 14, 2010 at 7:48 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    x2
  7. Jun 14, 2010 at 7:51 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Well we all use our differential system all the time-meaning that the drive-train will allow every wheel to turn at different speed - differentiating the speed of the wheels. If you are talking about a locker, where it locks the differential and no longer allows the wheels to spin at different speeds.... Only when I need it and only as long as I need it. Unless you are on very slippery/loose trail/road, you will put way too much stress on the driveline components!
  8. Jun 14, 2010 at 7:53 PM
    HBMurphy
    Paul
    So California Coast
    None
    To all of you that say before... unless you are on very loose stuff... you can delay until just before you are stuck... just sayin' you would be surprised how little you really need it and I promise you, the less you have it on, the better!
  9. Jun 14, 2010 at 7:55 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    well yea, im not saying drive around with it on the hole time your off road. if your coming up to a hill, click it on and get up the hill then switch it off once your up ;) or on for a mud puddle and turn off after...
  10. Jun 14, 2010 at 8:02 PM
    HBMurphy
    Paul
    So California Coast
    None
    It may be different where you wheel but after you get used to using as little as possible you may like it better. jus sayin I personally would like to have a trigger on my steering wheel to pop it on and pop it off!
