DILEMMA: Popping noise over bumps after lift
Discussion in 'Suspension' started by Jez, Jan 23, 2012.
  1. Jan 23, 2012 at 7:42 AM
    Jez
    Jez [OP] Hittn' easy steet on mud tires
    Ohio
    06 Black DC TRD SR5
    K&N air intake, Fox 2.5 coilovers, Total Chaos UCA's, AllPro Expo rear leaf pack, Fox 2.0 rear shocks, Diff Drop, U-Bolt Flip kit, Drive Shaft shim kit, Weathertech's, Borla cat back, Ultra Gauge,Clarion Radio, 18% tinted windows all the way around, smoked tail lights and rear break light, painted front chrome grill black, stained yellow fog lights, black head light mod, Interior LED kit, LED reverse lights, black leather arm rest mod
    *Before you bust my balls about using the search button please understand I have been searching for three weeks and have not found a solution to this specific issue*
    Three weeks and about 900 miles ago I installed Fox 2.5 NON-RESI extended travel coilovers (set to 1.5 and 1.75 from top of threads to top of adjustment ring) and TC UCA's. Since then I am noticing a popping noise when going down the backside of a speedbump, hitting a pothole going down the road, or driving off-road. I have read thread after thread, checked that all bolts are tight, ensured the bottom of the coils are facing the front of the truck, jacked the truck up and tried to wiggle the wheels to see if it is a bad lower balljoint, and even had the wife drive it over some rough spots while I stood outside trying to locate the issue. It is only heard inside the cab and only on the downside of a bump as if the coils are bottoming out. The cv angles are decent. Also know that I ran a 2.5" spacer lift for a year and a half before upgrading to this.
    I assume it is not the balljoints (although have a suspicion) since there is no play, not the cab mounts because it is only isolated to the downside of a bump, and not the LCA bushings as I do not notice it any other time like many have pulling out of of a parking spot or turning corners.
    Your thoughts or experience would be great!
  2. Jan 23, 2012 at 3:34 PM
    Jez
    Ohio
    06 Black DC TRD SR5
    No thoughts after 33 views?
  3. Jan 23, 2012 at 3:39 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    Maybe the uca is hitting the coils?
  4. Jan 23, 2012 at 3:40 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Did you tighten the UCA bolt while the truck was on the lift, or at rest?
    Your hypothesis that it's the extended length suspension topping out sounds like a decent one to me.
  5. Jan 23, 2012 at 3:48 PM
    Jez
    Ohio
    06 Black DC TRD SR5
    No the brakes were just done a few months back and I haven't noticed this until the lift was installed
    Maybe? I looked but cannot find any scuffs on the UCA or the coils. I did notice though that the driver side UCA is closer to the coil than the passenger. I can stick my whole hand down along the coil between the UCA on the passenger but not on the driver side. My knuckles hit...
    I originally tightened the UCA bolt when on the lift and most recently checked while at rest. The hypothesis would make more sense if I hit a huge rut in the road but not going over a speed bump at 5 mph. I just find it hard to believe this Fox set up would bottom out with only a few inches of drop?
  6. Jan 23, 2012 at 3:51 PM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    Check your UCA bolt, mine made a little bumping noise after some hard wheeling and it had come a little loose.
  7. Jan 23, 2012 at 6:26 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    So, how much total lift did you get?
    And how much droop do you get when lifting the front with a jack from at rest to wheels off the ground?
  8. Jan 23, 2012 at 7:28 PM
    Bee22971
    Bee22971 Well-Known Member
    Garth
    Sacramento
    2011 DC TRD
    King 2.5 C/O, DSM UCAs, all pro leafs, and AllPro Sliders
  9. Jan 23, 2012 at 8:03 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Most likely its your sway bar bushings. They crack pretty easily and especially if your running an extended travel coilover. Unbolt it and let it rest on the skid plate and drive around the neighborhood being careful not to get to crazy with it resting there. If you don't hear the noise, proceed by removing the skid plate in order to pull it out and enjoy the extra travel your not getting by having it on. Suspension will feel WAY smoother and you'll prob jiz at first!
  10. Jan 23, 2012 at 8:12 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Come on, its not that bad! The stiffer coilovers do help compared to stock though. Who the F would swerve at hwy speeds in a lifted truck anyways? Slowing down first and turning to one side only is the best option!
  11. Jan 23, 2012 at 8:34 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Totally understandable......I've had to make a manuever on the hwy and handled it well although it was crazy. I have quite a bit of pre-load and think that does change the oversteer characterists of the truck. When it was cranked dwn it was alot softer. I can however understand that's its sketchy and takes getting used to and not the best option for some! Be safe man!
  12. Jan 23, 2012 at 8:49 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Removing the sway bar as a diagnosis step is fine.
    Whether it otta be left off or not is a religious war off topic to the OPs problem.
  13. Jan 23, 2012 at 8:56 PM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    spindle hitting coil maybe?
  14. Jan 23, 2012 at 8:57 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    have had run this set-up my thoughts are:
    the upper arm is hitting the coil on droop because you mentioned noise happens on its way down
    characteristics of running no bushings/rubber between the shock mounts and vehicle
    loose suspension components
    sway bar bushings
  15. Jan 24, 2012 at 7:49 AM
    Jez
    Ohio
    06 Black DC TRD SR5
    Having run a spacer lift for the past year and a half which I did not install myself I am not sure what my exact numbers are. When jacking the truck up I do not get a ton of droop. If you are leaning toward the coils being cranked too high I only cranked them a 1/2" driver and 3/4" pass.
    Yanked the sway bar a while back thanks to your advice:D I really didn't notice much and now that the Fox coils are installed it really stiffened her up. I call BS on the safety issue of it...just my $.02
    Maybe but I cannot find any markings, scuffs, or scratches on either the coil or the UCA
    This was my first thought... it is tight but I can stick my hand down alongside the coil and the UCA at full droop. It really does sound like a bad ball joint or almost like the top mount of the coil is sliding around in the bracket but I have triple checked everything is tight. :notsure:
  16. Jan 24, 2012 at 10:52 AM
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    2011 TRD SPORT 4X4 DC
    RHLM (Red Headlight MOD), Cobra 29 WXNWBT, Devil Horns, ARB Bumper, Avid Stepbars, Homer Taco Satoshi thin lip grille, ICON UCA's, ICON EXT Travel up front with King 700# springs, Toytech 2 inch AAL with ICON VS 2.0 shocks in the rear, K&N Drop In, AVS Ventshades and Bugflector, Whelen SPS 660 emergency strobes, Redline Hood struts and tailgate EZdown, Illuminated 4X4 Switch, TRD Floor mats, Flyzeye LED lighting, Kragen 7" HID behind grille, Kragen 4" HID back up lights, Rigid SR Series 10" LEDx2 Elusive elements Lightbar, Firestik antenna, Rear Diff breather mod, Fogs anytime, Hitch Safe, OEM door sill strips, mryo mirror relocate bracket, Prinsu designs roof rack, Tepui Autana RTT, ARB Awning,Engo 10k winch synthetic, Blue seas fuse block and breaker,
    Id had this problem after my 5100's install. And it was the swaybar. The nuts have to tightened using an allen key to prevent it from turning. Get under truck, grab sway bar and shake. If you hear it pop or it moves then theres your answer.
  17. Jan 24, 2012 at 11:02 AM
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    :facepalm:
  18. Jan 24, 2012 at 11:31 AM
    Jez
    Ohio
    06 Black DC TRD SR5
    Don't have the sway anymore...
  19. Jan 24, 2012 at 11:51 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Doesn't really matter what you've cranked them to, right? If there's very little droop left, you might be topping out over speed bumps.
    And you can measure from the center of the hub to the bottom of the front fender, as a point of comparison against other lifted tacomas, even if you can't compare to your own old original "stock" measurement.
    Since you bought a fox factory coilover assembly, that tends to rule out improper reassembly of the shock and spring as would be a possibility if you were running bilsteins and eibachs, or some other shock/spring set you assembled yourself.
    I'm afraid I'm out of smart or stupid things to suggest. Good luck.
  20. Jan 24, 2012 at 4:10 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Ya, what are your measurements? In your pics they don't look to cranked up??
