dim dash lights after replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by greenseaman, Jan 6, 2014.
  1. Jan 6, 2014 at 7:57 PM
    greenseaman
    greenseaman [OP] Well-Known Member
    Scott
    Conway, SC
    2003 Tacoma Ltd Dbl Cab
    I just installed a Sony head unit in my 2003 Dbl Cab and I replaced the dash bulbs in the instrument panel with incandescent blue bulbs. The lights light and dim but are not very bright. Are they just really dim bulbs or is something else going on. Everything else works right... Do I just need to break down and get LEDs? Thanks!
  2. Jan 6, 2014 at 8:02 PM
    BamaToy1997
    Bill
    Navarre, FL
    I would think perhaps the bulb coating is limiting the amount of light? I would have suggested that you went with LEDs instead. They are much brighter and will last forever.
  3. Jan 6, 2014 at 8:09 PM
    greenseaman
    Scott
    Conway, SC
    Thanks a lot, I'm searching superbrightleds right now for the neowedge for the climate control too!
  4. Jan 6, 2014 at 8:18 PM
    Zer0
    Zer0 Well-Known Member
    SGV, California
    99 PreRunner
    what dash lights are you replacing? are you replacing the climate control bulbs? my bulbs seem dim in this area and one of the bulbs is blown. are there brighter lights available in the market
  5. Jan 6, 2014 at 8:34 PM
    greenseaman
    Scott
    Conway, SC
    After researching I'll probably just do the instrument panel lights right now, it looks like the climate control is tinted and you need to get a panel from an 02 4runner to change it from orange to another color... The gauge cluster is 194s.
