Dim Front Right Headlight
Discussion in '1st Gen. Tacomas (1995-2004)' started by fatban, Oct 19, 2011.
  1. Oct 19, 2011 at 2:45 PM
    fatban
    fatban [OP] Member
    Recently I noticed my front right ( passenger side) headlight has gone dim. Ive switched bulbs and still same side is dim, so its not the actual bulb. I was reading somewhere that it could be a blown plug (part that connects bulb to wires), but was wondering if anyone else has had this problem? and what did you do to fix it? I went by a toyota dealership and they were charging $9 for each wire x3, so basically $30.
    To note, I installed some HIDS about a year ago, so this may have been the reason for the blown plug. I switched out to my old bulbs and still passenger side is dim, so its NOT the actual bulb itself.
  2. Oct 21, 2011 at 1:48 AM
    fatban
    fatban [OP] Member
    still a cyclops!
  3. Oct 21, 2011 at 2:26 AM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    i’m no help. but i’ll give you a bump.
  4. Oct 23, 2011 at 12:30 AM
    fatban
    fatban [OP] Member
    New headlight sockets spliced in.....still DIM...wtf!!
