Dimensions of a second generation leaf spring 4WD
Discussion in 'Technical Chat' started by Pinoiako916, Apr 4, 2014.
  1. Apr 4, 2014 at 6:26 PM
    Pinoiako916
    Pinoiako916 [OP] Well-Known Member
    Al
    Roseville,ca
    SR5 2.7 4x4
    Stock
    What are the dimensions of a 2011-14 tacoma, access cab 4WD's leaf spring?
    What I mean is overall length, and the distance from the center of the spring to the front shackle and the distance from the center of the spring to the rear shackles.
    The reason why I am asking is because I plan to put on narrower leafs, looking at overall lengths between 42-46 inches on a second generation 4wd.
  2. Apr 5, 2014 at 10:28 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Can't you just measure yours? :confused:
  3. Apr 5, 2014 at 10:32 AM
    Pinoiako916
    Al
    Roseville,ca
    SR5 2.7 4x4
    Stock
    Is it possible to put in narrower 66-77 Ford Bronco leaf springs on a second gen Tacoma? I am not into the whole thing on flexing, but I am looking for narrower leafs so that I can cut more frame behind the rear leaf spring shackles to improve approach/departure angles.
    The narrower Ford Bronco leafs are 21-24 inch from center to front shackle and 21-24 inch from center to rear shackle.
    Also, I understand that the stock second gen leafs are 27.5 inch from both center to rear and front shackles.
    What is your advice on this? Can this be done.
  4. Apr 5, 2014 at 10:33 AM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    check out OMD s leaf thread, 4WD is his user name
  5. Apr 5, 2014 at 10:34 AM
    Pinoiako916
    Al
    Roseville,ca
    SR5 2.7 4x4
    Stock
    whats the link to OMD's thread?
