Dimmer Wire tap on 3rd gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ekimerpud, Mar 10, 2016.
  1. Mar 10, 2016 at 12:52 PM
    ekimerpud
    ekimerpud [OP] Well-Known Member
    Fort Worth, TX
    I'm wiring up some switches and I'd like the illumination to dim/brighten with the rest of the dash lights. What's a good wire to tap into? Preferably under the steering wheel or drivers side.
    Thanks in advance.
    -Mike
    boston23 likes this.
  2. Mar 10, 2016 at 1:03 PM
    proven21
    proven21 Well-Known Member
    Sterling, VA ( Loudoun County)
    2016 Taco DCSBOR 4x4 - Super White
    OME 90021 Front Strut 2887 Coils & OME N182 Rear Shocks, Wheelers Progressive AAL Pack, TC UCA's, BFG TA KO2 285/70r17 w/ 17" Method Wheels, AVS Window Visors, CoverKing NeoSupreme Seat Covers (charcoal/black), Mobtown Offroad Sliders, Relentless Fab. Bed Rack.
    tap the one that goes to the rear bed light switch
  3. Mar 10, 2016 at 1:10 PM
    StreetTiresJay
    StreetTiresJay Well-Known Member
    Jay
    British Columbia Canada
    '16 Taco TRD Sport DBLcab Alpine White 6M
    Wife in passenger seat, not driver seat :)
    I know the trip reset knob near the odometer should have a dimmer wire connected... Not sure how all the electrical works but it should be there. If you twist that little reset botton to the left or right it changes the odometer brightness... Try connecting to that?
  4. Mar 10, 2016 at 1:26 PM
    Liquidmantis
    Liquidmantis Well-Known Member
    2016 MGM 4R TEP w/KDSS
    I'm sure that dimmer isn't an analog potentiometer though. It's sending a control signal and the actual illumination voltage or duty cycle is from a controller.
  5. Mar 10, 2016 at 1:28 PM
    StreetTiresJay
    Jay
    Word...
    < this guy is not electrically inclined haha
    Gus87 likes this.
  6. Mar 10, 2016 at 1:44 PM
    ekimerpud
    Fort Worth, TX
    Any idea which color wire? If not, I'm sure I can figure it out.
  7. Mar 10, 2016 at 1:56 PM
    proven21
    if i recall correctly its white to green, blue to redyellow1, redyellow2 to pale green accessory switch tie in????? Pretty sure thats right.
  8. Mar 10, 2016 at 6:09 PM
    ekimerpud
    Fort Worth, TX
  9. Jun 4, 2018 at 11:37 AM
    TJK
    TJK Member
    Todd
    2018 Tacoma TRD offroad
    Painted bumper caps, door scuff plates, hidden bumper light bar, adding factory tonneau cover
    Adding switch for light bar on drivers side in cubby panel looks like the tan wire that goes into bed light and tan that goes to auto lights is the dimmer wire, but it brightens on the switch when I dim the dash lights.. Any insight
  10. Jun 4, 2018 at 11:38 AM
    TJK
    TJK Member
    Todd
    Pic of wires
  11. Jun 4, 2018 at 11:40 AM
    TJK
    TJK Member
    Todd
  12. Feb 6, 2019 at 12:37 AM
    LandLover
    LandLover Well-Known Member
    Andrew
    17 Tacoma Limited
    Anyone using Bussmann RTMR fuse/relay with CH4X4 switches? Need advice on finding dash dimmer tap (see below).
  13. Feb 6, 2019 at 9:26 AM
    caribe makaira
    Caribbean, Puerto Rico
  14. Feb 6, 2019 at 8:49 PM
    LandLover
    Andrew
    17 Tacoma Limited
    Yup that did it. I want to add some courtesy lights at drivers feet, passengers and backseat can I also use this tap location for that as well?
  15. Feb 6, 2019 at 9:24 PM
    caribe makaira
    Max on that circuit is 7.5 amps...I've no clue what the additional load would be for the unknown added lights you'd be installing...in theory, yes.
  16. Jun 5, 2019 at 8:39 PM
    derelique
    derelique Well-Known Member
    Derek
    2004 Tacoma
    I’m confused on the wiring to get it to light full brightness when the lights are off then dim once the headlights go on. I got the dim working with the ILL+(light green) wire. It looks like the OP has it working the way I would like to get it working but I can only get it to turn on when the lights are on or I hit the button to activate the ARB compressor. Or... Am I totally dumb and that’s how it’s supposed to work?
    I realize that paragraph above is kind of confusing. So in short: I’m missing the full brightness when the headlights are off, all other functions are working.
    The OEM have a ILL +/- (light green/tan). The CH4x4 only has 1 wire for the illumination or dash lights. What am I missing?
    Thanks in advance!
  17. Jun 5, 2019 at 8:48 PM
    caribe makaira
    Some of the CH4x4 rocker switches are Carlig switches. Without knowing which you have...:notsure:
  18. Jun 5, 2019 at 8:55 PM
    derelique
    Derek
    2004 Tacoma
    I have the 4 wire push switch similar to the one above. Green/red/red/black.
  19. Jun 5, 2019 at 8:57 PM
    caribe makaira
    Sorry I don't know if those are dimming compatible...
  20. Jun 5, 2019 at 9:00 PM
    derelique
    Derek
    2004 Tacoma
    The website doesn’t say anything about it being dimmable. Good call! Lol.
